The death song of the 245/45/R16 tire
#31
Funny enough, I don't remember what they ran as rain tires.
#32
I was/am about to buy the RA 1 in a few weeks
I was down this road a few weeks ago
https://rennlist.com/forums/racing-a...88-x-post.html
https://rennlist.com/forums/944-turb...88-x-post.html
I was debating whether to get a set of 18's but my opinion changes like the wind!!
I am probably just going to get he RA1's and if I decide to go to 18's so be it ..
Interesting info.... Thanks
I have a set of those Turbo Cup wheels, but unlike the stock Club Sport wheels, that came with the Turbo S cars, the front wheels are 8's, so the can handle that wide of a tire in the front. I ran 245's up front with those cup wheels and they were great (but unlike the cup cars I ran only 245 in the rear)
Regards
Ed
Regards
Ed
#34
The 944 works very well with 17" wheels and tires. I have setup many cars with 8-9" wide front wheels and 9-11" wide rear wheels, depending on suspension setup and street vs track. Using the same or very similar width front and rear makes for an excellent handling track car.
#35
Another creative option for you guys looking to stay with 16" wheels is the Kumho Ecsta XS [excellent max performance tire BTW] in 225/50 and 265/45-16 sizes. The 265/45 fits easily on 9" rear wheel and is closer to the OD of 225/50 than the 245/45 size is.
#36
Well
Still working out assorted kinks in the car.. but I bit the bullet and bought the RA1's today ...
Hopefully they will come by the time I work out my issues with the car ...
Regards
Ed
Regards
Ed
#37
I have a pair of 8 inch club sports from my 928 GT. Would 245 45 16 work in the front with the 265 45 16 in the rear? Like the idea of a larger tire protecting the vulnerable edges of the club sports, especially if your running 225 in the front and 245 in the rear.
#38
The Turbo Cup wheels have a very different offset than the 944 Turbo S wheels
They are like 55 or 58 ( can't remember ) maybe even 52? vs the stock turbo s wheels which are like 62 .... ?
There is little to no room if that offset is closer to the cars interior .. Ask me how I know ....
When I was tracking the car at the Glen years ago, I wore into the fender/wheel liner and was rubbing the tire into the fuel and brake lines at he bottom of the wheel well ... It was rubbing at- 2 degrees camber ... at turn 2.
I have a video of the rubbing sound, I had no idea what it was until after I got home and took the wheels off and saw the hole through the plastic liner
As for the rears I have no idea, as I stayed with the stock size tires and the Turbo Cup wheels which are 9's like the stock ones
Good luck
Regards
Ed
#40
Guys on Pelican are posting about Bridgestone RE11s from Tire Rack in 245/45x16 and 225/50x16. In the uk will still get SO2s, T1Rs and Contisports plus R compounds from Toyo and Kumho.
#41
I know a guy who runs 225/50/16 on all four corners and says the car still handles very well. That size is more readily available and probably will continue to be than the 245/45/16. Obviously not the best scenerio for track use, but around town it should be just fine.
A set of Star Specs or other decent tire in that size on all four wheels should work well, No?
Opinions?
Opinions?
#45
