Center Exit Exhaust
I do think it could look cool. Just trying to imagine how it would work.
Don't let us stop you from trying. You may figure something out in there we simply have not imagined yet.
Don't listen to these guys... if it isn't off the shelf bolt on... it doesn't exsist..
I LIKE different... I like to walk to the beat of my own drummer... I like having the only car out there that is how mine is...
Do it... post what you did.... If you build it they will come!
Rennlist Small
Business Sponsor
Rennlist Small
Business Sponsor
Geez, it simple – just put a down turn pipe end close to a short muffler in the stock location and then add a couple of fake tips in the center of the car…..
I have always subscribed to the form follows function concept. Adding bends will impact the function – so if looks are that important just go with the suggestion in paragraph 1!
See I was thinking maybe under the transmission. The pipes are going to be small, so clearance is no issue. Im thinking some heat wrap and shielding could help with heat. Chris, you do have a point about all the bends impacting function. So I've got a few ideas to help keep the bends down.
I'mm still considering it .. i had thought cut n shut the rear right difuser so it looks like the left one wheel well out and 2 3' pipes going just under the inner CV's 4"muffler full lenth of the torque tube
