First Impressions: Vitesse Sledgehammer head
#32
Yes it is, the way his car was setup it didnt handle well and the engine was a disaster. I pulled the engine after three tries at the track as it was overheating and rebuilt it. We also took another 150 lbs out of the car. The biggest thing we did was completely redid the suspension, springs camber and toe settings, ride height even the rims were wrong. It now handles like a dream.
Its making about 340 at the wheels at 18psi of boost based on my experience as I had it dynoed last year at 355 at the wheels at 22psi and I am attaining almost the same speeds at the top of the straight running 18psi.
Light is the best for everything, braking, acceleration as well as wear and tear on components. The only issue I have had with the car is that it builds quite a bit of crank case pressure. I had the AOS venting to atmosphere via a Lindsey catch can and now I am tryiing to pull a vacuum on it with it hooked up to the turbo inlet. Hopefully that will help.
I came in first overall in G70 and second overall in GT2 last year. This year I will try and run three series and win them all if I am lucky!
#33
What class does the car run in for SCCA? GT2? I noticed the GT-1 badge, but that can't be right -- I'm assuming that's for PCA or something else?
Just curious. Great car, btw.
BTW, I'd recommend going with a Saiko-Michi catch can. I've also got the LR unit and it doesn't work well at all. It's clear there wasn't much (if any) engineering that went into it.
I know the guy who makes the Saiko cans, and they're excellent. Beautifully-built, and top-notch quality. It's been on my to-do list to buy the can.
http://www.saikoumichi.com/product_line.html
#34
You are reading my mind as I am in talks with the Saiko guys and am currently ordering a can for my car as I hope that helps with the breathing problem. GT-1 is just the fasted class of bracket racing we do in Canada. I run GT-2 in PCA and will likely run GT-2 in bracket racing this year as I will try and run three series per weekend and if I have to run 23-24psi of boost to do it I think my baby will explode. For fun I will try and run it ***** out in one of my series but only if the tires dont get shredded as I want to run one weekend per set of slicks. More than that is a bit silly for a $5 plastic trophy.
I have never run SCCA so I am not sure as to what the classifications are??
#35
Rennlist Junkie Forever
I'm not sure about PCA, but in NASA and POC no 944 would ever be competitive in GT2 (assuming a properly prepped car with an good driver). GT3 maybe.... but only a maybe. You'd have to be running the full race Yokohama slicks to eek out a win there...
I run in GT2 and get smoked by the 911's running NT01'. Even down the straights... at best I'm dead even with them (since the class is power to weight ratio).
That's why I'm selling my LS1 951.
TonyG
#36
Rennlist Small
Business Sponsor
Rennlist Small
Business Sponsor
Just letting you know that I recently installed a Vitesse Sledgehammer head to go along with my Vitesse Turbo and Headers. My car is a 2308lb 944 Turbo with Moton Double Adjustables, a Kolken rear suspension setup, 2.5 litre block, TEc 3 electromotive system etc.. It can typically match a 2004 Cup car at the track and I have posted a 1:27.88 last year as my best lap tiome at Mosport.
I had the car out last week and managed to do the same lap times at Mosport as I did the prior year with 4 psi less boost. The turbo spool up is noticeable quicker and if I get around to dynoing the car I will post dyno results. I am trying to get more life out of my car and if I can run less boost it will be easier on everything especially my wallet! I highly recommend the head as I have had nothing but good luck with Vitesse products and thought I would share my findings with you.
#37
Yes the car is working out great now so thanks for your tuning expertise Chris. We had the fuel pressure a little high at the beginning but as soon as we corrected that it was a breeze to tune.
I only run one PCA race a year and you are right that I am not competitive in GT2 but I have a lot of fun beating Cup Cars in the other classes. Thats priceless!
#38
aromocki:
Just wondering why you are not competitive in GT2? I got bumped into GT2 because of weight (2150lbs) so I am getting ready. Are you out HP'ed or something else? Just wondering since I am now in the same boat? The few times in the past I ran with higher class cars it was not an issue but maybe I just don't have the fast guys???
#39
aromocki:
Out here GT2 cars are basically 996's that have 911 GT3 or cup car suspension, huge brakes, big Yoko slicks, and 911 GT3 motors, custom close-ratio transmissions gear sets using Guard 50/80 diffs, and very light weight (carbon fiber roofs and body panels), on and on....
The cars are blisteringly fast and are running at 996 Cup Car speeds or better.
The 944 platform just can't compete at that level. Ever...
TonyG
#40
If you're running an LS1 / 944 Tony this suggests that some customisation is allowed? So what about upgrading suspension and gearbox to mix it with them without changing your power or weight?
#41
![ooops](https://rennlist.com/forums/graemlins/icon501.gif)
It's basically anything goes (for the most part). There are a few restrictions like stock tub, stock firewall, etc... but it's pretty much wide open.
It's pure power to weight ratio classing. Slicks at a small penalty over R compounds but not enough (if you're running the $2200 per set Yokohama slicks). You gotta run that tire.
Once you get these 911's built right, they only need about 330RWHP - 350RWHP to pretty much kill anything else (but it does cost well over $75k to build one with all the right stuff that will win).
Pretty amazing really.
TonyG
#42
IF you're winning 50% of the races, I think you're doing pretty good. That sounds "competitive" to me.
Also, $75k for a 996/911 hybrid car compared to a $35k (?) 944/corvette hybrid that wins 50% of the time.......?? What am I missing here?
#43
That would be a hopeful 50% of the time in GT3... Not GT2. My car would never come close to winning a GT2 class race. The GT2 class cars are running at pro level 996 Cup Car speeds.
And I have a lot more than $35k in my LS1 951.
#44
Who was that guy running around with an LS conversion and rear suspension changed out to that of a 'Vette? Steve something from memory. Sounded like he had a pretty competitive car?
Also for sure you'd have more than $35k into yours Tony but what if you were to build one from scratch again without going through a lot of trial and error?
#45
To make sure I'm understanding, Tony's problem is that he ISN'T winning 50% of the races. He'd rather jump down to GT3, take the weight penalty, and win 50% of the time (because apparently it's still competitive enough in GT3 that even winning that much is difficult.
That said, if it's basically anything goes, I see a good bit of improvement in the suspension of a 944. Over the past year or so I've been doing some modeling on the 944 suspension and by my calculations there's definitely some room for improvement. Simply lowering the force-based and kinematic roll centers show marked improvement in grip, despite the increased roll moment and elastic weight transfer.
If you can modify the pickup points, it'd get you far. Unfortunately, the rear suspension is a bit more fixed than the front, which can pose problems.
