chassis bent? update P3
Sean,
I wouldn't say 100% the frame is bent. The roof area (when equipped with sunroof) is one of the weakest areas of our cars due lack of reinforcement. A momentary bad A-pillar twist can redistribute to the roof area without the result of a trashed frame.
Need to get in there....and very sorry to hear of it. One of the best looking/performing cars here.
Rennlist Small
Business Sponsor
Rennlist Small
Business Sponsor
Sean,
Sorry it see it go, its tweaked beyond repair (at least affordable repair).
Basic Sponsor
Well, let me break the news to you, I already parted one from Yuma, early January. I don't mind going back there again.
![thumbsup](https://rennlist.com/forums/graemlins/bigok.gif)
Basic Sponsor
lart you are one fu**ing handsome dude i can make mucho bucks sellng your *** on any corner in manhattan!!!!
It was more of a serious stump. Had it been 45 minutes earlier it would have been a lot more serious.
The rear wheel actually broke all the way around. It is an OE 10" twist. I have never seen that before.
If it was just some of the mechanical parts (sway bar end link, brake duct, nose, splitter, possibly a strut and control arm so I can sleep at night) and a little buffing it would not worry me too much but the roof has me concerned. There is very little bent exterior sheet metal, just a small ding in the lower fender.
I'll call you tonight....
I thought Lart generally wears a blue and white stripped apron ..
People are really odd about bent cars heaps of race cars get banged up and straitened every week .
if it is an ok car and functions well ,, can you close the roof ? and get a reasonable wheel alignment ?
Or just get it to feel OK on the road ..
.... keep it and drive it into the ground ..
1 Post
George is a kind and generous person. Many thanks.
To the parter group. No it will not be going anywhere but my shop if it is a salvage.
Spyder348, if you were tying to be funny then I must say **** off in the most humerus way. If you are serious then **** OFF!!!
I agree it does not look good and I will see what the status is once it is on a frame rack.
Whatever happened was a driving error. The car goes where your eyes go.
I talked with him, and there was tree trimming around a place with some roads any of us would love. Elevation changes, tight corners with angles that allow water to run downhill, etc. These are public roads, and he was not being an idiot. Two of his wheels got off the pavement, and he hit a loose tree trunk that probably wasn't there prior to the tree trimming. We've had much more rain here than years past over the winter, and these desert trees are growing like weeds.
I will call my body guy at http://www.hispeedcustoms.com/. I've known the owner for over 25 years, and if it can be fixed, John and his crew will get it done. I've had my share of cars in his shop, as I've made my share of mistakes.
Lart, if it's a total, we'll let you know.
az, despite what others say any car is repairable. Take it to a good body shop with a proper frame machine. I can assure that a good frame tech can get the car pulled back to spec.
