Crankcase/lower gasket set?
does someone have a list which gaskets there are in the set?
iīve search the forum but couldnīt find it.
itīs a victor reinz gasket set
is the transparent sealing ring for the oil pickup?
and do i need to use some kind of sealant to the oilpan gasket?
the engine is on a engine stand
I'm doing the oil pan right now and Clarks Garage recommends permatek Ultra Grey gasket sealant. Porsche recommends Dow RTV 730 ($99 per tube). I've also heard good stuff about 3m Weatherstipping adhesive 08034 but i can't find it anywhere.
NO sealer on the oil pan- ultra grey in the four corners- if you have a black/red gasket for the pick up tube use that. Ive actually used both since they are the same size- i believe the clear one is for the early cars?
i found a thread that said that itīs the clear one that i should use in the victor reinz set for the pickup tube.
can i use hylomar in the corners instead of ultra grey?
