Clutch Master Cyl
Not hard for a stock seat, but some race seat installs are like a Rubics cube. Because of difficult mounting bolt access, my seat takes over an hour to remove and reinstall.
Yeah, ours go all the way through with big washers, big bolts and nuts. It would take an hour for sure. What I need is my 11 yo to get more into the track car 5'4" and 92# is better than 6'1" and 210. Then to add insult to injury, I did some heavy squats two days prior to, and my a$$ hurt every time I would stretch those muscles. I was cussing myself...lesson learned.
I replaced my master entirely from the front. The actuator rod slides out of the rubber bellows. Slide the new master cylinder on over the old rod and you are done. Havent had a problem with it in many miles and years.
