Project 951 young man's first Porsche
Old 06-04-2012, 04:38 AM
  #436
NZ951
NZ951's Avatar
I love you Olli. So much intestinal fortitude.
Old 06-04-2012, 07:25 AM
  #437
Olli Snellman
Olli Snellman's Avatar
Love you too Andrew
Went to friends hot rod shop. Found there a very nice '56 Bel Air 4dr HT. One previous owner and 17K miles on it. California plates with '91 sticker on them.
Old 06-11-2012, 06:08 AM
  #438
Olli Snellman
We started to prepare rear suspension installation. More or less all necessary parts are here
Bought "some stuff". Almost complet 951 packed in boxes....
Parts are originally from my friends Pete's 951 he smashed several years ago
Started also work with my Bimmer project. Car is currently at our summer cottage, so it is more or less a weekend project during this summer.
Looks quite OK after wash.
Under carpet it does not look so good.....
Old 06-11-2012, 06:10 AM
  #439
NZ951
NZ951's Avatar
Oh I didnt know Pete crashed, his car was awesome... what a shame.
Old 06-29-2012, 05:36 PM
  #440
Olli Snellman
Son finished torque tube's surface. It's now painted with 2K epoxy. Turned out nicely. We are going to install new bearings tomorrow.
Old 07-01-2012, 12:21 PM
  #441
Olli Snellman
Tube bearing installation was postponed to Monday. Instead of it we prepared some smaller items like front spindles which were glass blasted, and painted with 2K Epoxy paint (4-layers)
After some grey anti-rust paint
After the first layer of Epoxy
4 epoxy layers
Tomorrow we are going to have a lot of bearings, so we can finally start to put under garriage parts back together.
Old 07-12-2012, 02:33 AM
  #442
Olli Snellman
We wanted to have a factory style dark green brake & fuel lines. We couldn't find locally suitable pipe and also factory offers new lines with other coatings, so we have to made new lines with our own coating.
Raw pipes were first shaped to the correct form. Then we applied special 1K primer. After that some 2K dark green epoxy paint. We are going to add some clear heat shrinkable pvc on that, so pipes will not get any rust on them.
Some yellowish primer
And dark green
We drove to our friend Harri's place (neva951 here on Rennlist). He helped us to press in some bearings
Beemer bearings in
Measuring temperature
Old 07-12-2012, 02:44 AM
  #443
Crazy Eddie
Crazy Eddie's Avatar
Awesome job
I had a similar dilemma regarding the short metal brake lines in the front of the car .. I wound up just plating them and then clear powder coating them
Regards
Ed
Old 07-12-2012, 06:14 AM
  #444
CarbonRevo
CarbonRevo's Avatar
Just read every page (in reverse order lol). Amazing project. I am doing somewhat the same sort of thing with my 1991 944 S2, except not QUITE as big. I won't be redoing door internals, AC/Heater system etc etc. But I have already restored my entire front suspension. Interior is in fantastic shape, so not much work needed. I've done as much cleaning and painting to the engine that I can without removing the motor. Soon I hope to drop the rear suspension and restore it. Then maybe pull the engine and re-do all of it completely as well as the engine bay. I would LOVE to repaint my underside, but that may be a bit unrealistic.
One main difference between this project and mine is I elected to re-paint most items. Wishing I would have spent the money for media blasting and powdercoating. Sanding everything by hand/dremel is very time consuming and tedious. I have definitely learned some tips/tricks and a new found inspiration/drive for my project.
Here is a sample of mine so far. The yellow is not as bright as it appears in the photo. Also a shot of my S2 and '87 951.
By carbonrevo at 2012-07-12
Keep up the awesome work! Truly an inspiration to people like me! Love seeing people restore their 944's!
Old 07-12-2012, 06:43 AM
  #445
Duke
Duke's Avatar
Looks great as usual Olli.
What epoxi paint are you using? Are you using spray can or do you mix the paint and use an air compressor gun?
Old 07-12-2012, 07:18 AM
  #446
Olli Snellman
Thanks, your project looks nice too.
Gustaf, we have used both spray cans and compressor gun. Colors are from Mipa & Lesonal.
http://www.mipa.de/gb/index.html
http://www.lesonal.com/lesonal/Pages/HomePage.aspx
Old 07-12-2012, 11:08 AM
  #447
reno808
reno808's Avatar
Olli looks great. when do you think you are going to have the car running?
Old 07-13-2012, 12:07 AM
  #448
eman930
eman930's Avatar
I can't wait to see what you do with the engine
Old 07-14-2012, 10:30 AM
  #449
Olli Snellman
We have not set up any date when 951 should be ready. Son's budjet is limited, so car is built more when he have funds available. Engine will be at first more or less standard 2.5L 8V. Evo version parts has been collected though...
Old 07-19-2012, 04:11 AM
  #450
Olli Snellman
To avoid solid (POM) bushings squeak, son made some "grease grooves" with Dremel.
Quick Reply: Project 951 young man's first Porsche
