Strange clutch system failure. Guesses?
Old 04-09-2010, 11:00 AM
Cole
Cole's Avatar
Question Strange clutch system failure. Guesses?
So last summer I put in a KEP pp/Cup new shift fork bearings/new throwout bearing/new slave cyl/rebuild the torque tube/new shift lever/resin trans mount.
In the last week the car has become harder and harder to shift. Two nights ago I pull into the garage and can't get it in or out of gear with the car running. NO CLUTCH action at all. Pedal is VERY light.
I checked the throw of the shift fork when pushing the clutch. It swings it's full motion. DOH!!! So it's not a hydraulic issue
Going to start tearing the clutch out of it today
Any ideas what failed?
Old 04-09-2010, 11:07 AM
Mark944na86
Mark944na86's Avatar
Location: Brisbane, Australia (Formerly: Sunnyvale, CA)
Bent clutch fork?
Old 04-09-2010, 11:12 AM
TRP951
TRP951's Avatar
well hopefully its not the same thing that happened to me before where the pressure plate diaphragm cracked
Old 04-09-2010, 12:13 PM
docwyte
docwyte's Avatar
Bummer Cole!
Old 04-09-2010, 01:46 PM
theedge
theedge's Avatar
My guess is the fork cracked and failed due to the stiffer pressure plate. It would have happened eventually with the stock pressure plate IMHO.
Time for a Blazack fork
Old 04-09-2010, 02:23 PM
Van
Van's Avatar
Disk too thin? Other people have had problems with disk thickness with the KEP pressure plate (Jerome951 comes to mind).
Old 04-09-2010, 03:52 PM
Rob
Rob's Avatar
I would guess either a pilot bearing going bad or a throw-out bearing/fork issue
Old 04-09-2010, 04:04 PM
jerome951
jerome951's Avatar
While mine wouldn't release w/ the KEP and 930 disk, the pedal effort didn't change between the thicker and thinner cup disc. If the clutch was working fine before I doubt this is your problem.
I'd guess either separation of the PP or TO bearing, or 1 of the fork tines broke/bent.
Regardless of the cause, it sucks to have to go back in there...
Old 04-09-2010, 06:32 PM
Richgreenster
Richgreenster's Avatar
Man I feel for you.
Old 04-09-2010, 09:02 PM
Cole
Cole's Avatar
Well I made small progress today. (shafts unhooked, exhaust out, 1/2 trans unbolted.). Then I went to the opening day for the Colorado Rockies baseball!!!!!
Hopefully I will get it out tomorrow.
Old 04-10-2010, 07:41 AM
Chris White
Rennlist Small
Business Sponsor
Chris White's Avatar
Worst case scenario – you trashed your thrust bearing….
For a quick check get a large screw driver or crow bar and see if you can make the crank move forward (pry at the front pulley – but don’t bend anything!). If you see movement then you have wiped out the thrust bearing….not good.
Old 04-10-2010, 10:35 AM
lart951
Basic Sponsor
lart951's Avatar
Kep PP diaphragm broke
Old 04-10-2010, 07:08 PM
Cole
Cole's Avatar
So strangely it only took us 2 hours to get to the clutch plate. We found the problem.
Is there a stronger option out there? Everything else looked fine.
Old 04-10-2010, 07:29 PM
Richgreenster
Why not just get one from Louis and then enforce it. It would be very easy.
Old 04-10-2010, 07:46 PM
Cole
Cole's Avatar
First, who is Louis?
Second, not sure I want to weld to the cast part. Also not sure how much I can do without it interfering with the throw out bearing.
This was an original part. So probably metal fatigue. (I hope).
Quick Reply: Strange clutch system failure. Guesses?
