No Spark
No Spark
The Mellium Falcon has had an intermittent no start problem for some time, but it is finnally doing it consitant.
In the past I have installed new crank ref sensors and even swaped a used DME. No help.
Currently it will crank no start. The tach jumps, but the coil is not getting signal. It has new ref sensor (as indicated by the tack jumping) and the orginal DME.
My current thoughts are to ohm the wire from the DME to the coil. If that is ok then try swaping a used DME again. Any other ideas????
Very intersting. I used a noid light and injectors were getting signal. I then jumpered the main relay (used paper to hold the contacts closed) and it started.
If it is only a relay then sweet, Cheep fix and the next beer is on me Carl!!
But, I am confused as to how I could have power through the main relay enough to have injector pulse but not spark???
