Car Almost Done. Shop Emailed me concerns.
#33
John. You are correct. Imagine my excitement (sadness?) with being on a trip and the shop telling me this. I need to try the car.
The Vflex is not yet installed. The dual port is only run as single port with the slow reacting manual boost controller. This is a base tune. I am 1500 miles from my car. Its done. And I can try it in a week....I am thinking this will be a long week.....
Or i fly home for a day....
-Dana
-Dana
I look forward to hearing your feedback.
#35
Also, I need to install Vflex and the MAP sensor to take full advantage of everything. So full power will still be a little way off.
I probably do need bigger/stickier tires. I just dont think with the offset of my wheel I can fit much more than a 255 under the rear.
Dana
#36
I know exactly how you feel. My car is at the cage builders right now, then goes back to the shop to button up the stage 2 install. I'm going full bore having the boost solenoid, MAP sensor etc installed. Plan is to run a 16psi street map, 18psi race fuel map and set 20psi as overboost protection...
My rear tires are 285's, we'll see how it hooks up.
