Tie rod end stud just spins?
Have you guys ever heard of the stud that comes up from the grease boot on the tie rod just spinning in place ? I was able to get off the lock nut that sits on top but it took some improvising... I used a air wrench on the nut and held the stud with a cushioned vice grip .... There goes 30.00 bucks ![Roll Eyes (Sarcastic)](https://rennlist.com/forums/images/smilies/rolleyes.gif)
Regards
Ed
Regards
Ed
There is actually nothing to keep it from spinning , if you are installing a new one just push it hard in to the spindle so it won't spin in the tie rod casting and or use your impact to tighten up while holding tight in to the spindle. I have taken a jack and ever so lightly held it in to the spindle while putting the nut on so the friction of it being in the spindle will let you tighten.
hope this helps.
Clifton
hope this helps.
Clifton
hope this helps.
Clifton
hope this helps.
Clifton
OK, just to recap, ALL these tie rod studs just spin ? So the tie rod stud is not broken or stripped?
Thanks Clifton
Best regards guys
Ed
Correct, they are supposed to spin. Same with ball joints.
See how the stud is tapered, wider at the bottom than on the top? When you re install it, that taper keeps it from spinning (or should).
