rotating noise on right turn
both hi and low speed but maybe when more when under throttle. thanks! i forgot about cv joints, now that i think about it sounds like my 85 jetta use to sound when the cv joints were about to go.
If it's a grumbling-like noise, quite likely a rear wheel bearing (tends to be louder when loaded under acceleration or cornering).
Raise the end of the car making the noise and spin the wheel. If the wheel makes some rumbling noise, it's probably the wheel bearing.
I have the same issue, more noisy when turns in gear or neutral. I've change the front wheel bearings, no use. I suspect the noise came from clutch hosuing or rear end.
I had this same "problem" right after reading this. Turns out one of my wheel spacer lug nuts had completely unscrewed and was rattling inside the wheel spacer...
Scary stuff but at least it was a cheap fix.
