Roof skin
Ok
so finally got around to fitting the roof skin. I removed all the spot welds on the old and new roof. I took the old roof off no problems as I did not need to be delicate with it. The new roof skin however is another matter. It is seperated everywhere apart from the 2 fron corners where is seems to be glued between the roof skin and the roof structure. I have tried to be gentle but to no avail. IT WILL NOT SEPERATE
anyone done this before? second picture gfives you an idea of where I am trying to seperate te panel
Pretty sure you can still buy them from Porsche if you get stuck.
I know Rod has done this with his 968 project. Sure there are others.
https://rennlist.com/forums/968-foru...ghlight=thingo
you can have tis one if I cant seperate this last bit (joke)
Please someone must know the secret way to do this better than my rough man handling approach which is bound to damage it
