Engine Management Advice for race car
What are the best options for an engine management system for a 951 race car? The existing one is >10 years old in a race car that has sat disassembled. Some parts got lost , etc.
Can someone point me in the right direction?
Todays piggybacks are pretty good with their perspective vendor packages, ie Vitesse with the SMT6, his chipboard for the DME with his turbo/MAF package, as is Lindsey with the MAfterburner with their package. CEP does LINK, Chris White has TEC3 - both stand alone systems.
My race car has LR system, with an older VR race chip. 17psi we got 351/348 respectively - haven't dyno'd the new engine but expect a bit more with the few internal changes we made, didn't make a change to the management package.
Rennlist Small
Business Sponsor
Rennlist Small
Business Sponsor
The one thing that I always toss out to people looking for an engine management system (standalone or piggy back) – its all about customer support. Check around and make sure that whatever product and Vendor you use give dependable customer support. Don’t be sold on ‘bells and whistles, glossy adds or even cheap prices – it the vendor does not support you the project will not be successful.
I just talked to a person yesterday (I can’t call him a customer – he got his ECU somewhere else) – I looked at his programming files and gave him some advice on why it was programmed wrong and what to do, it took about an hour but in the end he had enough of an understanding on how the system worked that he could work up his own program. The original vendor had charged him $3k in dyno time to tune the engine….and it was not running that well! Lets just say his was pissed bout the ‘tuning fee’ but very happy that he now understood how it worked and he could take care of it himself (with a little phone help!)
I might have a solution for you (!)…..feel free to call to ask questions – 315-636-8716.
I use Motec on mine but its from the same city as me ..
I think the perfect power looks realy good SMT7 and smt8.
Although its an old sytem plenty of people are pretty happy with varoius motrinic +piggy back rig ups and all the answears are here on this forum.
I think you have to kind of milk standalone to make it worth while ..
so you have to run multi coils boost/tps logging perhaps anti lag luanch control other wise its not realy worth the trouble .
also some of the sensors and trigger set ups need a bit of work to make good use of standalone ..
Rennlist Small
Business Sponsor
Rennlist Small
Business Sponsor
The other pluses of standalones are diagnostics, datalogging and the ability to easily tweak the tune. There are a lot of other neat things you can do with the extra outputs – it’s a ‘tweakers’ world. With the programmable tables in the general purpose out puts you can come up with all sorts of things.
My latest pet project is boost level set by throttle position – very nice for a high power street car.
Surely the amount of fuel required to alter the A/F ratio by a particular amount is something that could be calculated. Why has no one aftermarket got a system available that logs figures into the cells as you drive and then changes the fueling for those cells as required to correct the A/F ratio. Meaning the car is constantly filling in blanks (learning) and creating its own map of your driving?
I don't mean a 'closed loop' system which tries real time to adjust fueling as you drive (like my Audi did when the MAF wasn't working correctly) because I know the process isn't fast enough and the fueling is always trying to catch up.
I mean a system which saves the information as it goes so the next time you pass that throttle point the data has been adjusted. A car that constantly maps itself.
Rennlist Small
Business Sponsor
Rennlist Small
Business Sponsor
Rennlist Small
Business Sponsor
Rennlist Small
Business Sponsor
The Electromotive method allows you to review the proposed changes to the mapping and modify them before accepting the changes.
If youre talking about doing it on the stock system to tune the chips, that gets harder. It would be a software thing in the chip tuning software.
In any case, you need a wideband.
