Drilling the AOS increases flow as you make more power you have more blowby and need that extra flow to stop from creating positive crankcase pressure.
Drilling the AOS opens it up how much? Hardly anything. And the AOS must be removed to drill it out. It's not necessary, no matter your power output.
And if you want to argue on the side of ridiculous, you can say that at a higher output level you're moving more air and therefore pulling more vacuum.
if it were a dry sump, you could dictate whatever pressure differential you wanted and the gain would be more than 1 or 2hp.
why not try and maximize efficiency wherever you can?
I agree with maximizing where you can, although within reason. Not every car is a race car. If the AOS isn't out it's just not worth the work to remove it and drill, just for the single purpose of more crankcase vacuum. And even so, if the AOS was out and one were to drill it, the increase, if there were any, would be unmeasurable.
