Alex's 951 Build Thread (updated 11/4/10)
#46
Got new plugs, powdercoated IC pipes black chrome to match other parts, finished remounting the PS rack/control arms/sway bar, made wiring harnesses for euro fogs.
Waiting on my wastegate adapters (at machine shop getting threads tapped) and some T-bolt clamps...both should here on Friday. Going to work on the wheels tomorrow so I can get the tires mounted on Friday also.
So close!
So close!
#47
Haven't been around the car for over 4 months now as I was interning in Seattle. I now have a full-time position there and am trailering the 951 out there this weekend along with the rest of my stuff. Got a nice big 2 car garage just begging for some work to be done in it.
So far the car is about 85-90% completed. Things I still need to do:
-replace leaking fuel damper
-find wiring problem (pretty sure it's the reference sensor harness) don't believe the car was getting spark when I tried to crank it earlier this summer
-buy 3" dp and test pipe
-hook up exhaust/wastegate
-finish IC piping
-align panels and headlights
-redo headlights with dual lights (projector low beam and high beam)
-get it running and tune it
Also got a second set of wheels that I'm going to blast and powdercoat. 17x8/9.5" Atev/Azev Type A's
All washed up ready to go on the trailer
-finish IC piping
