Shift light
I have a question about the install of a shift light. I have a hot a ground and a tach or coil wire to hook up. My question is do I tap into the tach wire or can I hook it up to the coil on the 951?
The shift light is because you guys say and I am convinced that I need to quit hitting fuel cut and or spinning the motor past 6800 on a stock bottom end!
I am still use to shifting when the power falls off, but this doesn't work on my 951 hence the shift light.![Wink](https://rennlist.com/forums/images/smilies/wink.gif)
Max 951 chip and supporting mods.
