Early engine block 84 in a 951 86!!!!!
Can a earlier engine block (84) be use in a 86 turbo?? I have a friend with this problem, he have the 84 block already. I know that the problem is the oil line to the turbo, have anyone do a conversion or modification to get the line to the turbo, please advice. Thanks in advance
Are you asking can he turbo an N/A...hmm interesting question.
He only has the block? The balance shaft covers were matched to the blocks at the factory, but I don't know if that can be corrected. Also, I don't know if the oil pump from the '86 block is compatible with the '84 block.
no problem at all ..the oil line is very strait forward you just need a couple of drills and a tap ..
And if you are considering for a minute turboing a NA engine E85 is the answer josh and sid will back me up ...
Actually my current block and head is n/a...so I guess I have a turbo'd n/a don't I?
He has a 86 turbo, he broke the engine block, he have a n/a 944 for parts already, he is planning to use the n/a 84 block on the 951 86 car. can this be done?? thanks in advance for the fast replies
The Cartridge filter is a canton racing product, but in a similar vein you can use an "oil filter sandwich"
![](http://i55.photobucket.com/albums/g143/mikemarkota/1987%20Porsche%20944%20Turbo/oilfilter.jpg)
![](http://i55.photobucket.com/albums/g143/mikemarkota/1987%20Porsche%20944%20Turbo/engine2.jpg)
I believe you can use the block, balance shaft covers and girdle from the 84, as long as all the other parts are from a 951 (e.g. rods, pistons, head, intake, turbocharger, crossover, headers, cross-over, AOS, DME, KLR, oil filter mount, 951 oil pan (for turbo oil return) etc.). No guarantees you'll get acceptable piston-wall clearances though if you go with used mix-matched parts...
the early motors also didnt have line bored balance shaft housings like the 87+ cars- the balance shaft cover is separate from the bearing blocks. Should be on the turbo 86 block too. Only real thing i would worry about is the piston sizes v. bores.
Small Business Partner
If your 84 block does not have an oil-feed from the balance shaft (horrible location anyway, IMO). Then the simplest solution would be to get a T-fitting for the pressure sensor (like this Click me) and then run a A/N line over to your turbo.
Easy, done.
Easy, done.
Basic Sponsor
Some of the early 944NA blocks have much thinner cylinder walls. Compare those. If they are thin,
I would not use that block on a turbo. We wouldn't want to build a NA motor with them. All other issues are doable.
Mike or Dave Lindsey
www.lindseyracing.com
U.S. 1-877-943-3565
Other 1-405-947-0137
U.S. 1-877-943-3565
