engine rebuild
I have worked with them on various projects. They will do a very good job. Eric is a straight forward guy, talk to him about the various aspects of your build.
They love to use alot of paint marker and as a result your rebuild cost big $$$.
Honestly, his work is great I never see a car that he has touched come away with obvious signs of fiddling. That being said I don't think his work is justified in cost. I know what he charges and for the work I see performed I usually take my palm and put it strait into my face. However, if you have the money and you want it done right they do a good job but there are better options out there IMHO.
What would you suggest near the Detroit area? Really don't have lots of cash to do this. put 3 used motors in the last 3 years and just want a fast reliable Motor if possible? Thanks
just curious what seems to be the problems with the other engines? i can understand 1 out of 3 but not 3 out of 3 seems like you are doing something to cause catastrophic failure?
Just pokin fun at ya...
And teh saying is..
You Can Have it Good
You Can Have it Fast
You can Have it Cheap
Pick any 2 together, but you can NEVER have all 3.
This applies to all things in life, and has been amended to high performance cars to be:
Fast, Cheap, Reliable... Pick 2
And *IF* the snow would ever subside on a weekend, I might actually get the engine back in the car. It's literally sitting in my laundry room, completely finished, waiting for the Gods to warm the Earth for a week or two. And I've got SERE school in March, so I would LOVE to get the engine back in the chassis before then.
First motor was used and very fast for 2 years, and then the rod bearing went. Took to a local shop to have rebuilt and the price was way to high and they had a used motor he thought was good and my second event at Mosport blew head gasket running 15lbs boost and seezed the #1. Found another (reliable) used motor and that lasted 2 years and at Road America was loading up on long right turns and would puff black smoke and then run fine. The next event the next year engine loses power and turn off right away coast in and coolant overflows with engine off and tear that one down with bad #2 rod bearing and a bent rod and that puts me here.
Okay, wait!
If you are using these as track engines than that changes the whole equation.
Now it's
cheap
reliable
fast
good
pick two.
Here's a hint...3 of those 4 require that you eliminate any chance at 1, in combination.
Now it's
cheap
reliable
fast
good
pick two.
I agree Stienels is top notch, they use to maintain my car when the PO owned it. I sent a buddy there to get a lot of work done on his turbo and it came out with the attention to detail I expeced from them. They are not cheap but if you want it done right some times its worth to pay the piper! What are they quoting you?
