Who can tune for my setup? Also, Which injectors should I order?
#36
On the Radar
Where do you guys install the resistors?
Do you cut the harness above the injector connector and solder them inline
with the wire and than heat shrink?
Anyone have a pic of installed resistors?
#37
yeah do a search for injector resistors but the best thing to do is the hard way sux but pull your dme find gray and gray and black wires which i think are the grounds. wire them in inside the car. heat from engine bay might distort resistance. the resistors get hot if run hard so maybe bolt them to a heat sink and mount the sink so its not touching much. you pretty much wire the 2 resistors in line of two wires. pretty sure terminal 14 and 15 on dme connector. hey bud if you have it running in a week or two lots of props. i thought my project would take a day its been a couple months and i feel like im further away from finished then ever lol
#39
im sure it would be ok and its weird they seem easier to find but why settle for maybe when 25w is the way to go. need to look and see what co. had them. i need to install them asap.
#41
hey budd why dont you read rogues DIY tunerpro thread and tune yourself. read and study it its neat and a lot better then paying hundreds of dollars to get chips upgraded. once you understand the values and charts you realize its not worth it paying 300 for chips.
