Who can tune for my setup? Also, Which injectors should I order?
how high of psi can i go with #55s? i plan on eventually way down the road upgrading my HG so i'd like to buy injectors once, are 55s fine to 20psi? if so i should be alright.
Rennlist Small
Business Sponsor
Rennlist Small
Business Sponsor
If you go with the dropping resistors I would use the Siemens 72 lbs injectors.
Basic Sponsor
Rennlist Small
Business Sponsor
Rennlist Small
Business Sponsor
Low impedance injectors are usually better performers - they can open quicker than high impedance....if your system works with them.
Low impedance injectors are a ‘peak and hold’ injector – the initial opening current will reach 4 amps and then a lesser current (typically 1 amp) is needed to keep the injector open. The wave form is not a square wave signal.
High impedance injectors are a saturation injector – they are driven by a simple square wave – usually around 2 amps. Not as quick to open as a low impedance injector.
You can use a low impedance injector in a high impedance system by using resistors to minimize the current draw. High impedance control units systems are not built with injector drivers designed to put out the current needed to run low impedance injectors. – They will work for a while…but the injector driver may eventually die from overloading. You also won’t get the nice peak and hold signal so the low impedance injector will not perform as well.
All that being said – the 944 system is actually right in between the two! It’s a fairly uncommon mid impedance system. Some folks have run low impedance injectors without issue – I would still recommend using some resistors to better match the injector to the driver.
MAX 951 will burn a chip with my mod list, as long as I change my maf, so i'm just going LR stg 2 maf kit. anybody want to buy the autothority maf w/ intake tube and partial wiring harness with plug?
PM me!
