SFR Stage 3 T61 turbo upgrade..
http://speedforceracing.com/index.php?productID=748
Is this turbo a bolt on that requires no mods for fitment? Obviously fuel is a factor, which injectors would you run with this snail? Thanks!
I just finished installing a 60-1 Hi-Fi, stage 3 turbine with 8cm hot side and ceramic ball bearing center that I purchased from Tim. All I can say is HOLY ****! My 2.7ltr has never ran this strong. I'm only tuning at 15 PSI right now and am realizing this before 3000 RPM. 1st gear is useless. 2nd gear is basically useless, 3rd gear starts to get traction. This is only with 15 PSI. Can't wait to change to the race fuel map and turn up the boost to around 18. Great compliment to my Vitesse V Flex and 83lb injectors. ![burnout](https://rennlist.com/forums/graemlins/burnout.gif)
Tim is the man when it comes to these turbos. Great price. Great service. Great knowledge. Call him!
I have a similar turbo, 60-1 HiFi with #8 hotside. Also only running 15psi and it is very fast. Spins 2nd (275 width Kumho XS) if i get on it hard and a quick 3rd gear pull is just about all i need to pass or make people think twice. Spool up is ok (1-bar by 3200 give or take), i am sure with the ball bearing and extra displacement its even better for 400hp944. Have not dyno'ed, but with how the car feels compared to my stock 26/6 at 265whp, i am sure i am at (and i say this being conservative) 300whp.
