Inexpensive Digital Scope...$70
There have been lots of posts on how to check the speed/reference sensors, injector duty cycle, idle controller and the real answer is " You need a scope"
I ran across a very simple, one channel digital scope that should work for measuring anything on the engine sensors.
Scope is $49.99 and the scope probe is $18.99. So for under $70, the price of a DVM, you can have a scope. All the parts are soldered on the board. The scope is fully assembled and ready to use.
Digital Scope:
http://www.dpcav.com/xcart/product.p...age=1&featured
Scope probe:
Digital Scope:
Scope probe:
I have tested some of the USB scope and for low frequency repetitive signal they work fine. The only problem is that you need to have a portable computer connected to them to see the signals and this can get awkward in the engine compartment.
The advantage of the USB scope is the ability to store traces and you can get them in dual channels.
There is an Australian company called Pico that makes a great single trace scope for about $200 (PicoScope 2104). It also connects to a USB port on your laptop. I have been using them for a few years at work with great results. It's capable of reading signals faster than a CAN network, so working on our old cars is no problem. Check out their website:
http://www.picotech.com
In any case, here is a picture of the back of the board. One thing to remember is that the board can run off of battery power. I would add two 1N4001 diodes in series with the positive lead to drop the voltage down a little. You can get them at radio shack. The power plug is a 2.1mm x 5.5mm barrel style plug. If you have as many wall wart power supplies as I do, just dig through them until you find a jack that fits and cut the end off. Make sure you get the polarity right on the plugs leads. Center is positive.
http://www.radioshack.com/product/in...ductId=2036268
Also check to Velleman HPS10. Very nice product, and I think I paid around $170 or so.
10MHz sampling rate, sensitive down to 1mV/division. Impressive performance and perfect for just about any tuning/sensor data work.
![](http://www.vellemanusa.com/images/products/0/hps10.jpg)
More info here - http://www.vellemanusa.com/downloads/0/hps10.pdf
That's a steal($70). The ones I used in college were arround 15K. We have them at work also and I can borrow one if I need but first I have to fresh up before I use them.
Thanks maybe I'll get one and build it later.
And it's got an adjustable external trigger, which is just what you need if you are looking at spark retard/advance etc.
Think I'll get one myself - I couldn't build it for that money.
Good find Brian.
Good find Brian.
