Big Reds?
the Lindsey racing site shows 6 options for the M030 turbo S
Big Black/ C2 turbo rotors
Big Black/ GTS rotors
Big Red / C2 turbo rotors
Big Red / GTS rotors
Big Black / 993TT rotors
Big Red / 993TT rotors
Hope this might help
Jason
Jason
I have Big Blacks on my car, though i'm not sure if they are from a 993tt or a 928 gts. My rotors have stress cracks around the cross drill holes and I need to get new rotors for them. Just not sure which ones unless the rotors for the gts and the 993tt are the same. Would also like to get slotted rotors instead of cross drilled. Anyone know anything about a possible difference in rotors from the two?
I thought the Mono blocks wouldn't fit on the Mo30 setup due to the bolt spacing?
The Stock brakes for a non M030 951 mount axially. (from the side) So a fairly simple "L" bracket is all that is required to adapt. So in that sense, Mo30 difficult. regular old '87 up easy.
But my problem is all the adapters for the regular hubs are made with the narrower bolt spacing for the 993tt brakes, not the 996tt mono blocks.
I would like to add that the '86's are different in that they need a completely different back spacing on the rotor than any of the newer models. And of course, they're a huge pain in the *** to remove/replace compared to the newer ones. Correction.. 1986 needs a different caliper adapter than the newer models.
I believe the difference is the MO30 hubs/spindles mount the brakes radially. (Bolts from top of the caliper) An adapter would be very difficult to do since the only difference would be a slightly wider bolt pattern that might not be enough difference to clear the origin holes. Those would have to be filled in with weld, and new ones drilled and tapped.. Not easy. The Stock ones mount axially. (from the side) So a fairly simple "L" bracket is all that is required to adapt. So in that sense, Mo30 difficult. regular old '87 up easy.
