Information on circumference of puricil at turbo 27/6
I have a silicone hose that slipped off the turbo. I have tried the t-bolt clamps in the past but as I tighten it slips off. I need to run and grab a good hose clamp, but by the time I get home and remove it to measure the stores will be closed. If anyone can measure in MM the diamiter of the puicil at the turbo if have on off? , I would appreciate it.
Steve
Steve
Steve, Which turbo and which J-pipe are you using?
Thanks, you are correct. Its early and a Monday.
I have a 27/6 so, the diamiter would probably be different. So you have a average circumference of the puricil that goes around the cold side. I need to get an appropiate size hose.
Steve
Steve
