Autothority Maf Kit
#31
Small Business Partner
Well, I know for a fact I'm running way too rich. Just finished installing my wideband and I read 10:1 when I mash on the gas before boost hits in. I idle at 13.5:1 once warmed up, and in the 11-12.5:1 when cold lol.
Normal cruising is around 14.2-14.7:1 and under full throttle its is in the 12's until almost redline it goes into low almost high 13's
That's with fqs set to +3% fuel and adj fpr at 3 bar and old LR chips that allow fqs changes.
I need to probably set the fuel to -3% and do fpr that way so that it doesn't run so rich down low.
#32
Drew turn the pressure down a little bit and see if it helps,. You are putting to much fuel and that means carbon build up.
#33
No - do not turn down the FP. You are already way to lean at WOT; most likely knocking as well.
You are too rich cruising, and not rich enough in boost... Need to get that thing tuned, or re-chipped.
#34
Uhmm after reading it again you are right. Lean up top. Rogue by the way when are you going to start messing up with MAF with the ostritch.
#37
Yeah guys I'd hardly call what I have a tune! Up until yesterday I had no idea how rich I was though. I'll be doing -3 then -6% (compared to what I'm running now anyways) fuel through the FQS switch and I'll see if that doesn't help the low/middle end of the rpm. What afr should I be looking for at cruising?
Also I have a set of injectors on the way and hopefully a maf soon to fix all this, at which time I'll seafoam the car to help get rid of some of the build up.
#38
Drive-by provocation guy
So if you take 6% of fuel out you will be 6% leaner across the board.
If anything, go +6% so the upper revs are safe and just be richer in the mid. You will not wash out the cylinders unless you are REALLY rich; i.e. 9:1. And before you get to being so rich as to wach out the cylinder, the car would barely run from being so rich. If it is not bucking and stumbling/bogging, then it is not ultra rich.
#39
You can not "tune" with the FQS. That adds/takes out fuel across the rev range. You need a new chip or a piggy back that can adjust fuel in specific rev ranges.
#40
Also, if requested fuel is not being met, turning down requested figl does not neccesarily mean I'll run even leaner.
If I request 103% fuel and receive 95% it's the same as requesting 100% fuel and receiving 95% as the injectors are the limiting factor not the fqs settings. Is there even a +6% fqs setting? Thought there was only -3 and -6, maybe I have that backwards
#43
Thanks, and I don't want you to think I was saying you're wrong earlier, just that it might work the way I mentioned it. Perhaps not though as I'd have to actually test it to find out. Do you think the +6% would help to richen the top end even if the injectors are maxed? Guess I'll try that first before I risk going leaner
#45
Yeah, I thought about that. I was reading that you raised your fuel pressure pretty high when you were on stock injectors. I do have 75#'s on the way though and I'm purchasing a maf today so I'll just wait for that stuff instead of being silly with the stock injectors.
