Autothority Maf Kit
If you have stock injectors, and you're running the boost as instructed by Autothority, there's no reason that the MAF kit shouldn't work straight out of the box; no tuning from other sources necessary.
There's something else up with your car (low voltage somewhere, fuel pressure regulator not working properly, weak fuel pump; just to start) or maybe a false reading from the wideband.
I'm almost 100% sure. I already spoke with Russel Berry and he's going to take at the fuel maps. I also ordered is MAXHP kit with different maps.
Sebastian how's your AFR's.
That's right Sebastian sorry If I didn't say it correctely. Russel is going to read my current DME chip and it's going to add more fuel. I also got his board and he was nice and offered other maps to see if one works correctly. Really nice guy, I wonder why he got banned from rennlist?
Normal cruising is around 14.2-14.7:1 and under full throttle its is in the 12's until almost redline it goes into low almost high 13's
![nono](https://rennlist.com/forums/graemlins/nono.gif)
That's with fqs set to +3% fuel and adj fpr at 3 bar and old LR chips that allow fqs changes.
I need to probably set the fuel to -3% and do fpr that way so that it doesn't run so rich down low.
