Requesting fixed headlight info
Old 12-09-2009, 03:45 PM
jasonlp
jasonlp's Avatar
Default Requesting fixed headlight info
I'm looking for the best looking solution that takes up the least space
Thanks!
Old 12-09-2009, 03:51 PM
Rogue_Ant
Small Business Partner
Rogue_Ant's Avatar
Depends on what space you are wanting to save... My fixed kit (D9) was very quality, but took some time to install, and I lost space behind the headlight compared to stock.
-Rogue
Old 12-09-2009, 03:58 PM
333pg333
333pg333's Avatar
Jason
http://tinyurl.com/yhpswz9
Your car looks great Joshua!! I would say that though wouldn't I.
Old 12-09-2009, 03:59 PM
Rogue_Ant
Rogue_Ant's Avatar
Thanks! I figured it was time to update the avatar...
I thought you would like it
Old 12-09-2009, 04:10 PM
jasonlp
jasonlp's Avatar
to create more space
Old 12-09-2009, 04:13 PM
marcoturbo
marcoturbo's Avatar
-Rogue
Could you elaborate ?
Any pics with the bonnet open ?
I thought the fixed headlights kit with the removal of the wind stoppers (brackets) gives more room behind the headlights than stock pop-up.
Old 12-09-2009, 04:20 PM
Rogue_Ant
Rogue_Ant's Avatar
I'll see if I can get a pic.
Directly behind the headlight there is less space then stock (with the bracket cut). This is due to placing the actual lamp further back. But there is now usable space under the headlight, since the headlight does not retract.
-Rogue
Old 12-09-2009, 04:29 PM
333pg333
333pg333's Avatar
Plus of course you get rid of all the motor and attached mechanisms that operate the pop ups. Decent weight saving.
Old 12-09-2009, 04:32 PM
333pg333
333pg333's Avatar
Not perfectly clear but you get the idea.
Old 12-09-2009, 04:45 PM
jasonlp
jasonlp's Avatar
Where did you find the buckets?
Old 12-09-2009, 04:49 PM
marcoturbo
marcoturbo's Avatar
Thanks Patrick
Old 12-09-2009, 04:59 PM
951_RS
951_RS's Avatar
Anyone have pictures of these on a silver car, I'm considering these in the future but I'm just not sold on the looks quite yet
Old 12-09-2009, 07:18 PM
LS1Porch
LS1Porch's Avatar
There's these, too:
http://www.944hybrids.com/accessories.html
Feedback on them sounds pretty positive.
Old 12-09-2009, 09:06 PM
gt37vgt
gt37vgt's Avatar
well the way to get the most space is do a custom set up in driving light space as it is all square and simple you can put up to 100mm projectors in there and upto 4 sets (not4x100)
Old 12-09-2009, 10:39 PM
333pg333
333pg333's Avatar
From before...
Quick Reply: Requesting fixed headlight info
