Caster blocks. M030 vs 968?
Just bought a set of the upgraded 968 types from the dealer and they had one of those made in Italy stickers on them .
Ordered one of the e-bay sets and they are absolutely the same for 1/2 price.
Clifton
Clifton
You might take a long look at the ones you have. If they are original they are good and old. When I replaced mine they were visibly worn.
In any case, the 968 blocks a much better.
That's pretty common. There are a couple of reliable ebay sellers of 968 blocks. I've bought two, and they were exactly the same as factory, for significantly less money. Porsche doen't actually manufacture them anymore.
Same as OEM??
Just want to make sure before i order.
$10 per item or $20 per pair cheaper
and from a RENNLIST SPONSOR
http://www.lindseyracing.com/LR/Pors...41-023-01.html
http://cgi.ebay.com/ebaymotors/ws/eB...K%3AMEWAX%3AIT
price is per pair...
price is each
price is each
It's also worth noting that if you replace the stock 16" wheels with anything larger, the rubber bushings in the stock 951 caster blocks will fail and blow out. BTDT.
While we're on the subject, i keep hearing about how Porsche recommended a few upgrades if running 17's or larger. So the 968 blocks are one thing, what else is there? (Sorry, i'm sure this is a common question, but i searched a little and couldn't quite hit on the right search terms).
