Cheap wheel studs?
Anyone figured out a substitution for the Porsche wheel studs that might be cheaper.
I need some
901.331.671.01 72mm
911.331.671.00 65mm
To make my wheel spacers fit with late offset wheels on an early offset 951.
From Pelican this is $145 of studs. Just curious if there is another option?
I need some
901.331.671.01 72mm
911.331.671.00 65mm
+1 on doing some searching. I picked mine up (80mm) for about the same price each. Either way, it may be a bit expensive for wheel studs, but removing the rear hubs to install them is the hard/expensive part. I think I spent about $500 to have my shop do it, because I didn't want to risk damaging the studs on install.
Pormgb, what kind of wheels are those?
Done my rear studs in about an hour, the hardest part is reinstalling the parking brake cable and mechanism. The parking brake shoes,mechanism and cable are removed to allow enough space to get the longer studs in without removing the hub. I used the following link, very helpful.
http://members.rennlist.com/951_race...Q-spacers.html
With regards to wheel nuts, I used steel open ended nuts from my hub centric spacers, quite cheap on Ebay.
