Arrrgh - engine re-assembly issues - need help
#46
Going with the pack
is quite monotonous.
Someone told me they saw an overrevved SBC motor break rings in all of its cylinders one time.
A bit of a stretch, but hey anything is possible at this point.
#48
I find it pretty hard to seal the adapter that screws into the spark plug fitting in the head.
And you will probably have some leakage through the rings on the cold engine. So perhaps some air is leaking past the ring, but the majority of the air is going somewhere else?
Hey what's the compression numbers!? With 80% blowby you would probably don't have much compression. Do a comp. test and get back
If the engine was running before you pulled the head I would definately think something else is going on, and not that all cylinders all of a sudden are complete toast.
#49
Car wouldn't start and compression and leakdown numbers were poor. Leakdown air was coming out of the intake. I took the head to the shop and they said all four intake valves were very slightly bent. I think I over revved on a downshift at the track as that is where it wouldn't start.
Hi Duke - seems really strange to me too that all four cylinders would be go bad. Compression numbers were 52, 52, 87, 52 with a tester that I would usually get 135 across all four cylinders.
#50
Josh: I am sorry to read about all the engine trials you are having. Sounds like it is time to pull the engine and replace the rings at a minimum. Have you tried pouring any concoctions into the bores that could loosen up the carbon on the rings and in the piston grooves? My keyboard theory from 150 miles away is that the rings are frozen in the pistons or lost their tension for some reason. Maybe they got too hot.
#51
But still, bad results on all cylinders is suspicious.
#53
A crack is certainly a possibility. I currenlty don't have any water in the car - was trying to get it to start first. I could seal back up the cooling system though. Since I am getting lots of air out of the AOS on leakdown that is probably a bad enough sign.
