Arrrgh - engine re-assembly issues - need help
Well - bolted everything back together and it still won't fire. I pulled every single plug and I could smell fuel on each one. (brand new plugs) Grounded each one to the intake and got a nice strong spark. I have good oil pressure (5 bar) and the tach is bouning but the car just won't start. Timing marks are exactly on. So frustrated!
Just double checking, when you say timing marks are exactly on, you mean *both* the one on the cam gear and the one on the flywheel through the slot on the bell housing, right ? Also, check to make sure the reference sensor connectors are tight.
That short block probably hasn't been touched in a year at least.
Yup - Cam gear and flywheel marks are right on. Reference sensor connectors are tight.
Josh, Have you done a compression test? In order to run the engine needs: Spark, Fuel and compression. It sounds that you have Spark and fuel.
If you have compression, I would change the spark plugs just to eliminate a variable. then examine the engine temp sensor wiring, injectors wiring.
Josh,
Was this head the same one you had on the car when it was running? If not I would really be looking at that head. It seems to be the only new part. Why did you remove the head?
Sorry to hear this.
Mitch
Sorry to hear this.
Mitch
Are your plug wires on in the right order?
Speed and ref sensors both gapped correctly?
Tach bounces? You could try switching the speed and reference sensor plugs anyway. Worst thall happen is nothing.
Fuel pump runs while cranking?
Ok - did compression test and the numbers from one to four were 52, 52, 87, 52. When the car was running and I checked them last with the same tester they were at 135 +/- on all four.
I did a leak down test on number 1 with the crank and cam at TDC. I put a rubber latex glove around the opening to the MAF and on the exhaust tip to show me where air was going. Also I left the cap off the AOS. At 100 PSI I had 80 percent leakage. There was nothing coming out of the exhaust and nothing out of the MAF but lots out of the AOS. If I put the cap on the AOS then I got air out of the MAF. I disconnected the line from the AOS to the j pipe and got the same result.
I bolted this same head to my spare block and got only 20% leakeage on cylinder one so I don't think it is the head. I guess I have some sort of major failure in my block. I can't figure out how that can be without major scoring on the cylinder walls - they look fine!
If you have a nice straight edge, you can check the flatness of both the head and the engine deck. Use a piece of package cellophane (like from a cigarette pack) to slide under your straight edge.
Out of curiosity, how much do your o-rings "stick out" (proud above the surface)?
Quite clearly you have a combustion camber sealing problem. Either you deck isn't flat, your head gasket is damaged, your block is cracked or your head isn't flat (although it does sit *better* on the other block).
Hey Van - sorry - I do appreciate the help.
I think I can narrow those four scenarios down to at least two (deck not flat or block cracked) as I bolted this same head and gasket to a different block and got an acceptable leak down number on cylinder one.
I took a flat edge to the head around the o rings but didn't use the cellophane - just sort of eyeballed it and looked for a high spot but I couldn't find anything.
What could cause the deck to go out of flatness or the block to crack? How could the block crack in such a way that it affected all four cylinder chambers?
paper is about 0.003" thick, so that would make it 0.012" - 0.015" thick. (I don't know what's recommended for a stock or wide fire ring head gasket.)
You're right - a cracked cylinder usually only affects that one cylinder.
Could there be some deformation, burr, scratch, or bending that's keeping the head partially lifted up? Did this block ever fall and hit the ground? Or have anything heavy drop on it?
