Bigger intake valves in the cylinder head - Pics
I figured while I had the head off to fix my bent valves I should modify it some I had a few 2.7 liter 47mm intake valves on the shelf and so I went down to the local machine shop. They put slightly bigger seats into the head. The stock turbo intake valves are 45mm and the stock turbo intake throat is 40mm. With the new seats I have just under a 42mm throat. I am going from a area of 1257 sq mm to 1385 sq mm. That is about a 10% increase in intake throat area. From the pictures I've seen I think that is slightly smaller than what folks are getting with the larger chevy valve swap out.
I didn't have the head bench tested as their fee to do a before and after adds up quick. They charged $250 to put in the new seats and smooth out the throat area. I was short one valve and that was $140 new from Sunset. I still have to have the head re-assembled and that will probably be another $150.
Here are some pics. To the left and in the back is my 1000 mile head I have as a backup in case this doesn't work out real well For reference sake I will be running a Super 61/#8 hotside, 55lb injectors, Vitesse MAF/chips/piggy back, 3 bar FPR and SFR 3" exhaust. Also this head was already o-ringed and lightly ported/polished before I took it in.
It woud be interesting to know the flow comparison of a stock 951 head, to this approach, and then the 2.7NA head. All results with the same stock cam/valve lift. It would also be nice to know the same on the exhaust side ie 951 with ceramic ports versus the 2.7NA.
The 2.7 NA head is supposed to be a major improvement over the 951 head, it would be nice to know factual comparisons.
My request is a tad selfish as I have a 2.7NA head and had planned a 3.0 Turbo 968. Now I am not sure what I am going to do, and I would like to know independently how good a 2.7NA head is. It may influence my next decisions.
The 2.7 NA head is supposed to be a major improvment over the 951 head, it would be nice to know factual comparisons.
Hey Steve - yup - I am afraid it is. She should be back up and running by the end of next week though.
Probably should just take some brewskies over to that machine shop and see if they would let me play with their flow bench on a friday evening
That is a good idea! I have a Web-Cam from Lindsey - that grind #247 - that I put into the cam tower while I had it off. According to their website it has .480 lift, 254 duration, 234 duration @.050. Not sure how that differs from a stock turbo cam or compares to the NA cam.
