What do i need to do to get AC updated
As far as I know it is the original ac system the car came with. I've no idea what to buy to make it work as I don't know much about AC systems other then they no longer use the freon our cars came with. I believe the compressor still works and all and it probably just needs to be charged. If that is the case would having someone fill it with the new freon be adequate?
Rainman
first make sure no leaks
remove the R12
drain the compressor of the old oil (might have to remove it for this)
replace receiver dryer
vacuum out the system with the compressor back in
put R134a fittings on
put new oil in the compressor
charge the system with R134a
remove the R12
My winter work includes a full AC system overhaul with the Kit from 944 online,
http://www.944online.com/cgi-bin/ASI...ntrol-944turbo
and barrier style hoses from these guys..(it is illegal for a tech to fill a system known to have non-barrier style...like the original hoses...) as I don't feel the crim on barb style hose that comes with the 944 online kit will last long term with the pressures R-134 runs at...
http://www.rparts.com/Catalog/Instal...rubber_h&f.asp
and a new evaporator as it is what's leaking on my car... a new expansion valve for good measure... and anything else I can think of...
Rainman
If it is all new, it should work right?
