Spring rate change and torsion bar ?
Old 10-08-2009, 10:18 AM
v8killer
v8killer's Avatar
Default Spring rate change and torsion bar ?
Changing springs to 400lb front and 500lb rear. At this point do I delete the torsion bars are leave them? What will be the difference if I go either way?
Old 10-09-2009, 10:22 PM
caster951
caster951's Avatar
The consensus will be to delete the torsion bars, I sent you everything that you will need to do just that!
Old 10-10-2009, 03:07 AM
333pg333
333pg333's Avatar
Are you asking if after adding 500lb rear springs if you should remove the torsion bars? Sure as hell you should or get some replacement ones with very little rate. Otherwise you will have an extremely out of balance car. The advantage of t bar delete would be weight and the ability to swap out coils more easily. If you aren't going to swap out coils then some might say that you are weakening that area also by removing them....
Old 10-10-2009, 01:26 PM
eniac
eniac's Avatar
delete the torsion bars. There is nothing more you need to do other then simply take them out and put everything back together without the bars.
Old 10-10-2009, 01:48 PM
vt951
vt951's Avatar
Search for "motion ratio". I think you will find that you won't have enough rear spring rate if you remove the torsion bars. The effective (wheel) spring rate at the rear is much lower than the front.
Old 10-10-2009, 05:29 PM
333pg333
333pg333's Avatar
The wheel ratio of 400lb front and 500lb rear would be approx 340lb/in front and 300lb/in rear. That would probably fall into the ok category.
Old 10-10-2009, 06:09 PM
Bri Bro
Bri Bro's Avatar
At the spring rate you are going to, its sounds like it life is mainly for the track. I would delete the Tbar to allow quick changes to the ride height and spring rates.
Effective spring rate front is 0.94
Effective spring rate rear is 0.42
So
400 * 0.94 = 376
500 * 0.42 = 210
For a back to front ratio of 0.56
I try to be around 0.6 to 0.7. I would bump the rear spring up to 550. It is really a matter of how you like the car to handle. And the shocks need to be valved for these spring rates.
Old 10-11-2009, 01:07 AM
333pg333
333pg333's Avatar
Yep that's right Brian. I was basing my number off the motion ratio only which is about .65 but forgot that this should be squared which brings it back to .42 in which case I'd agree that the rears should be bumped up a bit.
Old 10-11-2009, 01:51 AM
ArthurPE
ArthurPE's Avatar
so if I go 200 front (oem is 126 correct) effective is ~190 (200 x 0.94)
and if I want a ratio of 0.65 R ~ 190/0.65 ~ 290 for the rear effective rate
I want to leave the TB's, so using: TB rate + (coil rate * 0.65) = effective rate
oem TB rate = 175
effective rate/rear = 290
solving for coil rate = (290 - 175)/0.65 ~ 180 lbs...
so ~ 250/250 on a coil over kit with TB's should be 235/340 effective? ratio ~ 0.69?
does this sound OK for a street set-up?
I'm thinking about the Paragon 1 Koni Cup kit
Old 10-11-2009, 02:12 AM
v8killer
v8killer's Avatar
So would a 600lb rear springs be a good choice if I want the car to have a tendency to understeer?
I hope this does not sound like a moronic question but is there is any chance the 500lb coilovers would have synergistic effect with the OEM torsion bars to put me at a desirable spring rate? Sorry never had a car with torsion bars.
Old 10-11-2009, 04:07 AM
964-C2
964-C2's Avatar
I thought it was 0,55-0,6 on a 944 (?).
Old 10-11-2009, 07:39 AM
333pg333
333pg333's Avatar
No, Brian is correct. It's .42 effective.
Old 10-11-2009, 09:36 AM
DanaT
DanaT's Avatar
Just out of curiosity, where are you get the formulas for the spring rate and motion ratio? I haven't seen this and would be interested in reading up on this.
-Dana
Old 10-11-2009, 06:02 PM
Bri Bro
Bri Bro's Avatar
Originally Posted by ArthurPE
1986 951
235/340 effective? ratio ~ 0.69? The ratio is rear to front so this would yield 1.44.
I would go 250 front an add 100 lb coils in the rear. I have heard that anything over 100 lb rear coil over requires that you re index the Tbar. You could also change the Tbar to 28 or 29 mm.
550 to 600 should give you a slight understeer with good handling. I would pull the Tbar, just makes changing the setup so much easier and I don't know of any advantage of running both the Tbar and coil overs.
-Dana
Nice write up from the BMW side. My original link is broken, so it got moved somewhere.
http://www.e30m3project.com/e30m3per...e/eff_rate.htm
Sway away had a nice tech write up but it appears to have been replaced by a calculator spreadsheet. Might contact them and see if they have the original write up.
http://swayaway.com/TechRoom.php
http://swayaway.com/calculators/diag...gArmModel.html
Old 10-11-2009, 11:16 PM
ArthurPE
ArthurPE's Avatar
so the front spring rate is > than the rear?
oem is F/R ~125/175 correct?
wouldn't 100 coils ~ 175 + 0.65 x 100 ~ 240 effective? ~ 1:1 ratio?
my BMW's all have lower in the front, e46 ~F/R 225/400 or so
M030 sways are on the 'want' list
Quick Reply: Spring rate change and torsion bar ?
