Best Intercooler for our cars ?
Old 10-05-2009, 02:04 AM
INURGRL951
INURGRL951's Avatar
Location: out in the sticks and flat lands of va wondering around for an open field or pavement!!!
A Lindsey Stage 5.
Old 10-05-2009, 02:31 AM
Olli Snellman
Olli Snellman's Avatar
is that a spray on the IC or a tank built around it with a water cooling loop?
That is my friend Pete's set up. It was a spray on IC controlled by boost. That car was wrecked about a year ago.
Have SFR modify your your end tanks. Easy job and it's fairly cheap.
If thread starter lives in Greece, Europe, is there any sense to send parts from Europe to California to be modified ?
I am sure there are cable aluminium welders in Greece as well.
Old 10-05-2009, 04:39 AM
marcoturbo
marcoturbo's Avatar
Olli, don't you have a close up pic ?
I wonder if you need to cut the brackets on the passenger side (or even on the driver side) to fit the modified IC
Old 10-05-2009, 04:47 AM
Olli Snellman
Sorry, no more pictures available. Brackets needs to modified, otherwise IC won't fit.
Old 10-05-2009, 05:42 PM
toddk911
Drive-by provocation guy
toddk911's Avatar
The best intercooler for a car is a chemical IC; ie. water/meth injection.
Cost less than half of a higher end/core size IC and allow easily to run 20-25psi all day long and now with a little more $ have fully control injection.spray and datalog injection etc.
Old 10-06-2009, 07:31 AM
Mikes3.0cabturbo
Mikes3.0cabturbo's Avatar
interesting section from Bell Intercoolers web site FAQ...
Does one style core cool better than another?
No, almost no difference. With three decades of testing intercooler’s, we have found no appreciable difference between any core style or manufacturer. Keep in mind, that the merit of a core is it’s efficiency versus its internal drag characteristics. When sized for a tolerable flow loss, virtually all cores will produce essentially the same efficiency results. Perhaps a core with slightly less flow area per linear inch, or one with longer tubes, will need perhaps 5% more tubes to equal the best of intercooler’s with regard to flow loss and efficiency. Not a very important difference.
Old 10-06-2009, 10:51 AM
brrgrr
brrgrr's Avatar
+1 on Stock or Stock with modified end caps..... (Lindsey Stage II, for example)
Old 10-08-2009, 03:45 AM
Olli Snellman
How about this kind of cooler
Old 10-08-2009, 03:59 AM
theedge
theedge's Avatar
Originally Posted by sh944
Sigh...
Read this in its entirity and see if it helps y'all (credit to JohnKoaWood for finding this link and posting it in another thread recently). The guys suggesting water misting have the right idea.
http://www.dvdtfab.com/intercoolertestlab.pdf
Ooo interesting....
Old 10-08-2009, 08:17 AM
333pg333
333pg333's Avatar
Hehe, I've seen one of those lately Olli and it's like something out of a Frankenstein movie with Boris Karloff!
Old 10-08-2009, 09:34 AM
Olli Snellman
Might look strange, but if original IC core can be used, i can easily made such a Water to Air mod about 40$
Old 10-08-2009, 01:03 PM
Duke
Duke's Avatar
But then you need an extra radiator, water pump, and routing. Plus the packaging problems.
Old 10-08-2009, 01:15 PM
Olli Snellman
Already have most of the hardware for water to air IC.
I am not going to use oem modifed IC either. A friend of mine consider this mod.
IC design i have planned does not allow to use air/air type of cooler, must go liquid
Old 10-08-2009, 05:25 PM
JohnKoaWood
JohnKoaWood's Avatar
Sigh...
HUH? little ole me? And to think, I recently got accused of being a link *****... I much rather prefer the term "link industry distribution specialist"
not OT, but unrelated... I am trying to track down my front mount IC from SFR if it matters... I am considering running it with a CO2 spray... and maybe add some meth injection just for kicks...
Old 10-08-2009, 08:12 PM
odb812
odb812's Avatar
Didn't Jeremy Himsel just do a write up on his findings with his intercooler replacement? I'm pretty sure he has a very specialized setup, but I think he has a Vitesse turbo as well.
Quick Reply: Best Intercooler for our cars ?
