Any interest in a group buy on wastegate adapters?
Working on "hardware" still and have been looking into drilled bolts. Only drilled bolts I can find though are SAE and I'm having the shop tap the plates in metric.
Alright, did some more research on hardware, there will be 3 options.
1.) No hardware
2.) Regular black-oxide socket screws (M8x1.25) - $5.00
3.) Drilled black-oxide socket screws (5/16"-24) - $11.00 (safety wire NOT included, can be found online for <$10 for way more than you'll need)
If there is interest, I could add a 4th option which would be stainless regular socket screws. They would be around the same price as the drilled option.
Once I get the first set of plates back from the shop I will start a new thread with an actual group buy.
Payment will be due up front and will be non-refundable.
I am going to initially limit the group-buy to 10 sets. If there is interest for more I will have to talk to the machine shop to see if they have the time to do more.
I will also need to know upfront what hardware package you would like. If you are ordering them without hardware then you will need to specify M8x1.25 threads or 5/16"-24 threads
1.) No hardware
