Snapped Intake Manifold Bolt
Ok, so on the 951 I was almost done at the end of summer, with only the intake left to put on. Of course for some reason none of the bolts, which I am 100% positive are the ones that came from there, wanted to go in easy. I had got some dirt in the holes from standing on the engine but I cleaned them out pretty well and I can't imagine that's the reason.
Anyway, of course one of the bolts sheared as I was working it in and out, and I took the whole thing off again and nothing is getting it to turn. I'm just about done cutting it off flush with the head and going to use a reverse bit on it and hopefully salvage the threads.
Has anyone had to helicoil these threads? If so, do you know what size helicoil I would need? Were you successful???
Any advice or stories would be great!
It should be a M8 - 1.25 X 35mm. If you're careful, the bolt can be drilled out without damaging the head. The goal is to drill straight down the bolts center with a small bit, then continue to step up the drill bit size until nothing but the bolt's threads are left. Then the coil can be removed with a pick and some needle nose pliers. I've been successful with this method on several occasions.
For the remaining holes and bolts, I suggest you get a bottoming tap to chase the holes and a die to chase the bolts. (or buy new bolts).
It should be a M8 - 1.25 X 35mm. If you're careful, the bolt can be drilled out without damaging the head. The goal is to drill straight down the bolts center with a small bit, then continue to step up the drill bit size until nothing but the bolt's threads are left. Then the coil can be removed with a pick and some needel nose pliers. I've been succesful with this method on several occasions.
Yeah I'm still miffed. It wasn't due to a misalignment of the intake I'm pretty sure, and I can tell from the threads and the holes that nothing is cross threaded, just were really stiff. The bolts were off since like may and we had a pretty wet summer, I'm thinking corrosion maybe, but the car is indoors, I really have no idea.
Via RI? Where are you in RI?
Rennlist Small
Business Sponsor
Rennlist Small
Business Sponsor
I have helicoiled many an intake bolt hole - even more fuel rail mounts.... easy fix.
General rule - never force anything, if its not going in right then there is a problem!
I've had many of these break....most commonly it's the bolt for the head coolant passage in the front which is the same as the intake bolts.
Everytime I drill the broken bolt out starting with a smaller bit centered then gradually work up to a larger drill bit thats just a tad smaller then the threads. At this point, the rest of the broken bolt should come out. I generally run a tap through it after to make sure the threads are clean but I have yet to need to use a helicoil on the intake bolts. There is one time on an exhaust bolt that the PO had tried to fix in the car so he had retapped the hole at a slight angle. To fix this I had to retap to an SAE size bolt just slightly larger then the metric threads. This was on my car and I did this 8 years ago and haven't had to touch it since.
If the threads are gone and you have the option of a Helicoil vs. Timesert.........go with the timesert.
good thread. i stripped out one for the fuel rail a while back and tapped it with a helicoil but I'm not real happy with the holding strength and of course the fuel rail isn't a place you want to wiggle loose.
I was looking at some videos on the Timesert site - one of them mentioned the 'bigsert' which is designed to fill a failed helicoil hole. Anyone know which size I'd need to fill that hole? How do you use the bigserts? do you just bore the hole out with a drill bit with the helicoil still in there, re-tap it then use the tool to put in the bigsert?
http://www.timesert.com/html/bigsert.html
Thanks all, I've drilled a lot of bolts out before just was curious if anyone else has saved the threads on these, so it sounds like I might be ok.
BTW, this turbo forum is great for support thanks for making it that way. The combined forum didn't get me hardly any response in a days.
