Balance Shaft - Bearing Cap Studs
Anyone have the specs of the bearing cap studs, for the balance shafts (-86 bearing caps separate from housing)?
Thanks!
Thanks!
Hi Bob,
Thanks for that. I'm actually looking for the specs of the studs themselves (for example: thread pitch, stud length, etc). I should have been more clear.
I need to drill and tap the holes for the upper balance shaft studs
Unfortunately, they're not listed in PET.
It appears to be item numbers 9, 11, and 12.
Item 9: M8 x 55
P/N: N 010 361 4
Item 11: M6 x 42 (odd duck this one is)
P/N: 900 075 349 02
Item 12: M6 x 50
P/N: 900 075 344 02
Item 9: M8 x 55
P/N: N 010 361 4
P/N: 900 075 349 02
Item 12: M6 x 50
P/N: 900 075 344 02
They are M8 nuts, so the studs will also be M8s, just do not know how long they are. Can you back one of the good ones out using the double nut process?
