CEP Billet Turbo mount and Tial Turbo (PICS)
Old 09-19-2009, 10:27 PM
  #61
ehall
ehall's Avatar
Originally Posted by 333pg333
Actually I'd have to say I think this is about the most ideal sized turbo for a street 2.5L 951 that I've used or been in. Really nice response and still quite a bit of a kick. I've been running it at 1.5bar and it sits there all the way through the rpm range. No falling off. I think it could take more with a few other mods, but this was really just an interim choice as I'd wanted to move to something smaller than the very good, but oversized VR stage 5.
I think with E85 and a decent amount of boost you can't go past this turbo. I will say that going in JET/Sean's 2.5L with VR s3 is also very good. Perhaps a bit more laggy and with a bit more of a kick up top. Wouldn't mind seeing that turbo at 1.5 bar though.
Good to see some choice here. The mount is great and from what I understand progresses from the one initially developed by the guys at Tial. The improvents have been made and Tial are aware of them.
As Chris says, why wouldn't they want to jump aboard the highly lucrative 944 market is beyond me.
Of what turbo do you speak?
ehall is offline
Old 09-20-2009, 02:10 AM
  #62
xtaC
xtaC's Avatar
This is relevent to my interests also
xtaC is offline
Old 09-20-2009, 05:00 AM
  #63
pole position
pole position's Avatar
Reading his sig will reveal that is a Garrett 3076.............still a relative small turbo.
pole position is offline
Old 09-20-2009, 05:02 AM
  #64
spoolin51
spoolin51's Avatar
Since patrick is out drunk, ill step in and say
Yes, he is absolutely talk about the gt3076r
spoolin51 is offline
Old 09-20-2009, 08:23 AM
  #65
333pg333
333pg333's Avatar
Originally Posted by spoolin51
Since patrick is still out drunk, ill step in and say
Yes, he is absolutely talking about the gt3076r
Fixed.
Yep, it's the GT3076. Sure, it's not a BIG turbo and it totally depends on what you want out of your car, but my belief is that this turbo would suit 90% of guys with 2.5s. Of course you can go bigger and get a more pronounced 'Whack', but I've had that. It's fun for a while and maybe it would suit a few guys, but it isn't ideal especially with the stock gearing.
When I get back I'll see if I can post some video. You will have to bear in mind that I have the shorter final drive ratio though. In fact with most 2.5s I would also suggest going to the S2 ring and pinion in combination with this or other similarly sized turbos.
333pg333 is offline
Old 09-20-2009, 12:09 PM
  #66
evil 944t
evil 944t's Avatar
From Garretts website, Gt3076r, 310-525(crank HP) so, I wouldn't say that this is a small turbo. Any larger on the street and your going to start to feel the lag.
evil 944t is offline
Old 09-20-2009, 12:16 PM
  #67
Duke
Duke's Avatar
I agree, that's not a small turbo. Especially not in this community where there are extremely few cars above 500 crank hp.
Patrick, are you sure it's not the increased midrange power that makes it feel like it has less power on top vs the other turbo's?
With a broader and more linear powerband the top end can sometimes feel a bit "dull".
Duke is offline
Old 09-20-2009, 12:17 PM
  #68
Chris White
Rennlist Small
Business Sponsor
Chris White's Avatar
The Gt3076 is a nice turbo, I am putting one on a 3.0 16v 9:1 street engine. Should spool fast...real fast.
Chris White is offline
Old 09-20-2009, 12:18 PM
  #69
Chris White
Rennlist Small
Business Sponsor
I agree with Duke - sometimes a turbo with a very wide power band does not 'feel' as powerfull as a turbo that has a noticable on/off effect.
Old 09-20-2009, 12:20 PM
  #70
evil 944t
evil 944t's Avatar
Chris, have you run one? Make sure you put the right one on. They make a few versions and "smaller" versions may be too small for that engine. Personally, I'd be looking at a small gt35 for that engine.
Old 09-20-2009, 04:44 PM
  #71
95ONE
95ONE's Avatar
um. Weren't we originally talking about the dinky little turbo in the picture? Definately NOT a GT30R. That thing looks smaller than a gt28!
A GT3076r is Labelled as "mid" size turbo, yet it spools similar to a small frame while giving a damn good top end. Truly an excellent turbo.
Chris, Ill see you a 16v 3.0 and ill raise you to 10:1 compression. E-85 twin scroll. I wonder if Ill see boost off idle? lol.
EDIT: ok.. just talking about 333's (Patrick) turbo.. Got it. 1.5bar. or 23psi.. What power did you see with that psi?
95ONE is offline
Old 09-20-2009, 06:00 PM
  #72
Chris White
Rennlist Small
Business Sponsor
Noramlly I would agree - in fact the track 16v has a Gt35 - but I like my street cars 'under tubrboed' a little. I get all my big HP jollies out on the track, for the street I want a very quick spool and boost down as low as possble. My wife's Audi S4 (old twin turbo type) gets up to 80% of its max torque by 1700 rpm.
With the 9:1 and street gas I will not be running big boost so the 'little' Gt30 should do the job nicely. Hopefully it will be up and runnign in a month or so...
Old 09-20-2009, 07:53 PM
  #73
evil 944t
evil 944t's Avatar
So, you haven't run the gt 30 yet, Which gt30 are you using? Have you run the gt35? Whats your impression of the gt35? What size is the motor and how many valves?
Old 09-21-2009, 11:15 PM
  #74
333pg333
333pg333's Avatar
You might be exactly right there Duke. I think the term 'Dull' is an excellent choice for what I'm experiencing. However it hasn't been in the car that long and we haven't done any dyno or real tuning of / for it. We've just played around with the fuel a little. It certainly 'feels' like it flattens right off past say 5500rpm but the two turbos are quite different so not a great comparison. Stupidly we changed some things on the suspension, swapped the turbo and have been running some Hoosiers...but I've taken 2 seconds off a 1.21 lap time at Oran Park with the new arrangement however I'm not quite sure what's the cause lol. The turbo itself is fantastic around any of the twisty bits and corner exit. It's pretty good in a straigh line too, just feels like it flattens off compared to the VR 5 is all.
Haven't dyno'd it yet Bruce. Not sure how far I'll take this setup either as I've seen my 3L in the flesh the other day. It's on the engine dyno but 6 hours later we still couldn't fire it up due to a faulty cam sensor!!!! Damn long way to travel to get that close and not see the $%^&$%^#$%^ thing start!!!
Erg.........
333pg333 is offline
Old 09-21-2009, 11:45 PM
  #75
evil 944t
evil 944t's Avatar
What Patrick also needs to add is that his timing map is set up for a huge turbo. He is probably leaving a ton of HP on the table as well as response.
Quick Reply: CEP Billet Turbo mount and Tial Turbo (PICS)
