Any special edition Turbo S's in 88? Barn find.....
#62
We all know that sitting for long extended periods of time is the worst thing for a car. Realistically between it not having run for ten years & and an electrical problem, there will probably be a lot of work to go into the car. Chasing electrical gremlins not mentioning ten year old ones, plus other potential failed parts from sitting might have it's challenges. Adding to the list - belts, hoses, fuel lines, etc. etc. which all need to be done immediately, there is plenty to do.
The body work looks simple enough, but metallic's like that are difficult to match & blend. I had Baltic Blue which the metallic caused the color to flip/change in different light. It really was very difficult to match right. Having said that, with time and money, the car looks to have the potential to be very nice. I wanted a Glacier Blue when I bought the Black one I now have. I gave up on that after searching/waiting a while and learning there were so few of them around, particularly with low miles.
I'd keep it, but wouldn't track it. Even though Porsche set the S car's up for weekend track fun, nowadays you can put better than S parts on another less valuable or let's say more common 951 chassis that you mind not mind beating the hell out of quite as much.
If you decide to sell it as is, contact me first please.
#64
THe biggest problem is that the cars just aren't worth what they used to be. It is getting to the point where it would be cheaper to just buy an S than to upgrade a non-S. I'm watching the prices on a few that are on ebay right now. And once I get it running, I may do some more searching. But if I wouldn't be able to get more than $10K out of it without investing in paint, then I think I'll be selling the white one next to it, instead.......and making this one the track car.
I appreciate all of the input, guys. And I understand your position. My GTO is all numbers matching, and when I first got it, I was nutso about keeping it bone stock. So much so that I was not able to enjoy the car as much as had I been willing to modify it when it would have made the car better. I learned my lesson, and swore I'd never do that, again.
#65
And I will. A non-track Porsche is not an option. I bought the first one to replace the old track car project (see sig). With three kids and two other classic cars, a third weekend driver is something I can't justify (and the kids can fit in the Bronco and GTO). Either this one will go, or the one next to it will go. Whichever one doesn't will get more parts to make it a more capable track car.
#66
So after I get all of that sorted out, I'll do some engine mods - my experience with the XR was that a MAF conversion is absolutely HUGE. I may try to make my old Ford EEC-IV stuff work, but more likely, I'll do a Megasquirt and have to deal wtih speed density. I'll probably fab up my own 3" exhaust, I've got a lot of mandrel bent stuff laying around. Internally, about the only thing I'd do to the engine is put bigger intake valves on it - I've read that the S' engine already has 1mm larger exhaust valves, and there is PLENTY of room for a larger intake valve. I may do my own intake, I've got some models I can play around with. I had at one point wanted to do a turbocharged 16V 3.0L, but I'm a bit less concerned with that than I had been. Like I said, it is all about suspension, and I was able to get 330 horsepower out of an iron head, small valve, small bore Ford, so getting a bit more out of this one shouldn't be too tough. I used to do engine development for Ford, so I've got a bit more of a leg up on doing stuff myself than most folks. Last thing I did was the earliest stuff on the new 5.0L in the 2011 Mustang.
#68
Thanks for the info!
#69
https://rennlist.com/forums/944-turb...a-turbo-s.html
Originally Posted by Oddjob
Exhaust valves have a different/larger dimensional spec on the valve stem – changed based on wear/thermal expansion. Not a performance difference, the valve head is the same diameter. I think the Turbo S valve part number is the only one still available from porsche for any Turbo model.
#75
Didn't the Turbo S's all come with sport seats? Your no start issue might be related to the coil wire not being connected. lol
I have an '87 Ocean Blue 951 thats been heavily built using a bunch of Vitesse equipment. Any interest in a swap (and no, it wouldn't be straight up, I'd need some cash as my car is very well sorted, heavily optioned and well built, sorry! lol)? I would kill to get a Glacier 951.
