Show your oil cooler!
Old 09-11-2009, 02:31 PM
Euro951
Euro951's Avatar
Default Show your oil cooler!
If you have an oil cooler different then the Kiss setup show us what you got....
Old 09-11-2009, 04:19 PM
SamGrant951
SamGrant951's Avatar
Setrab 619 mounted up front...
Old 09-11-2009, 07:54 PM
Skip Wolfe
Skip Wolfe's Avatar
Duals Setrab oil coolers - one tucked in behind each fog light opening.
Old 09-11-2009, 08:12 PM
Jeff N.
Jeff N.'s Avatar
Sam - you run that thing on the track? Did you see a bump in your water temps? TIA!
Old 09-11-2009, 08:27 PM
Van
Van's Avatar
I have a second factory cooler. Not as good as Skip's setup, but a lot cheaper!
Old 09-11-2009, 08:32 PM
Jeff N.
Jeff N.'s Avatar
Van - q to you (anyone figure out that I'm interested in coolers). I looked into this and had the following issues:
1 - this setup doesn't work with the A/C in the car. Yours looks out, correct.
2 - the wiring harness that runs above the cooler is also in the way. Looks like you moved yours or ???
PS - nice sway bar!
Old 09-11-2009, 09:19 PM
Van
Van's Avatar
My AC is out, but I don't see why that would matter. There should be clearance, and nothing would block the condenser.
Good eye. I was able to cut the plastic covering off the harness and route some of the wires (horn, left side fog, turn and marker lights) up. The other wires I was able to "fan out" a little so they took up less height.
PS - nice sway bar!
That's the Tarret bar. It's quite good.
Old 09-11-2009, 09:41 PM
David Floyd
David Floyd's Avatar
25 row Mocal
Old 09-11-2009, 09:51 PM
Jeff N.
Jeff N.'s Avatar
Thanks Van. I did a test fit attempting to do what you've done and ran into the above problems. The AC condenser is definitely a problem as the connection lines are right where the cooler fits. I don't have an answer for that one. (except to pull the AC).
You have a good solution for the harness.
Old 09-11-2009, 10:36 PM
SamGrant951
Its not my primary track car but I do try and take it out here and there. Havent had it out since installing the new oil cooler unfortunately.
My cars water temps are always very cool street or track so I dont think the oil cooler being there is going to make any big difference. I also dont have a condenser up there to worry about like some people. Cant wait to try it out as my oil temps were very high last few times out.
Old 09-11-2009, 11:05 PM
Chris Prack
Chris Prack's Avatar
Mocal coolers are very efficient and inexpensive. You can buy everything necessary from BAT in Fla.
Cake.
Old 09-11-2009, 11:09 PM
Euro951
Euro951's Avatar
This is good stuff.. keep it going....
Old 09-12-2009, 04:00 AM
95ONE
95ONE's Avatar
Got the Mazda one up front.
Old 09-12-2009, 05:17 AM
gt37vgt
gt37vgt's Avatar
sorry no pics but i do have a plan I'm going for 2 standard one's together right beind right indicator wich will come out and be turned to duct..
Old 09-13-2009, 01:33 AM
mj951
mj951's Avatar
I went with a pair of Setrab coolers and aluminum ducting...
Quick Reply: Show your oil cooler!
