Best clearance combination of strut brace and adjustable camber plates?
clearance combination? I have a cup replica tower bar and ground control plates and am very happy...also have ER monoball joints, Koni yellow coil overs, 300lb springs, rebuilt PS rack, new tie rod ends... street use only
![](http://i179.photobucket.com/albums/w305/avimgod/100_1741-1.jpg)
My concern would be top mounts (like racers edge) causing clearance issues between strut brace and hood
What I have noticed is... if it doesn't hit the hood, it will hit the engine or fuel rail... mine kisses the hood right in the middle... will be fixed this winter during paint and engine work...
the strut brace is all about what you do with the car... daily commute on highway, it makes no difference... put it hard into the twisty bits, and WOW what a difference...
I usually commute, but hit the twisties when ever I can manage to...
