Weird RPM's question
Hello everybody.
May I kindly ask you suggestions on what to took for if:
1. RPM's sometimes gets up to 1300 just without any case, stays there for some time and then goes back to 1000, usually when car is at normal op. temp. and city driving.
2. The car stalls during cold start, it goes up to the 1200 and then 0, after second or third start it sets on 900 (without touching any throttle), witch as far as remember seems to be little low for cold, i guess it was 1100 usually.
Thanks in advance
Thanks in advance
i concur with the ISV; this is the same symptoms as an NA i did work on. the owner had the same hunting idle problem and cold start hesitation. i unplugged the ISV and it idled fine.
