(Pile on) Tips for making your 944 Turbo reliable at the track.
#31
well coner balanceing is cheap speed but not relaibility .
I would say a 60 watt head light in the dash facing the driver with a big $ on it thats blinds the driver when the oil pressure goes below 30 psi of temp goes over 100C
best I've seen so far was a 2 red $ oil pressure light
#32
I disagree with this very much. By doing so you are removing a coolant path at the back of the block/head. Coolant will not flow as well and you will end up with #4 cylinder running hotter as a result. On race cars I have a Gates hose that is a perfect fit from the heater pipe over the headers to the water flange on the head.
Oil coolers, 1 large or two small - had great success with two factory units in series.
Just plain old good maintenance - you owe it to your own family and your fellow track buddies to bring a well prepared - and as safe as practically possible - car to any event. And, I hope to see some folks at Hallett in May!!!!
#33
Corner balancing is important - not having a 50/50 weight distribution. In fact, as you lighten these cars, they become a little front heavy. 50/50 front to rear weight distribution isn't possible unless you're willing to carry a few hundred lbs of lead around... And no racer wants extra weight.
However, I can't stress the importance of good corner balancing enough. Alignment too. Attention to this can make the car feel completely different (in a good way, if done right.)
#34
My car is lowered enough you cannot put a jack under the side of it. My white car spent over 350 days on the track without a failure. I replace the stock M030 arms with std turbo arms when the bj's finally got some play.
I have never seen a properly installed new arm fail due to ride height.
#39
#40
about the kiss cooler, can you mount it where the big alternator shroud and brake duct go?
i already removed the alt shroud and i want to remove the driver plastic brake duct, is it good?
#41
I'm surprised nobody has mentioned track time. If your on the track for hours at at time without stopping I can see the car start to misbehave or develop a problem fast. When i watch some of those youtube track clips i sometimes cringe .. because the car sounds like it's being punished in every corner and for how long?? I've been wanted to go to some lapping events in my area but each time I think about it i just know I'm only going to want to abuse the car for maybe 5 or 6 laps and be done for the day. Most track events are at least 4 hrs long..
#43
I think auto-x is harder on a car than DE.. that is very quick full on and full off, not to mention even harder on suspension i think with the bumpy lots they are held in.
#44
At first I thought you were kidding.........
I run the **** out of mine and in 10+ years I have had 1 burned valve (which I knew was coming but did nothing about) and I totaled 1 car.
For me it's not worth owning if I cannot run it hard. I am not a wax and baby diaper person. Cars serve a purpose, they are a tool for me to have a good time and nothing more. Going to the track is something that cannot be substituted by anything else similar.
#45
I once took my new Audi A3 2.0T Quattro S-Line to the track. Had it returned to Audi due to "brake noise". Mechanic told me the front brake pads were broken into 2 pieces, something he had never seen before. I played along, put on my surprised look and handed over the company MasterCard
