Dyno Results -- 493/498
#31
#34
Graphed 2 days ago!
http://reutterwerk.com/forums/showthread.php?t=12631
OH and in respect to the peaks, if you turn off smooth graphing, you will see it is held at the peak longer then the graph posted above leads you to believe...
![](http://i179.photobucket.com/albums/w305/avimgod/dyno.jpg)
In other words the wider you make the Power axis against the rpm one, the smoother and longer the graph tends to look. This is merely semantics of course.
I am also curious to hear how Tom is dealing with traction???
#35
Tom,
You can slap together a good motor. Can't believe it's been ten years in the making.
