Torsion bar delete. Is it safe?
Old 09-01-2009, 06:08 AM
964-C2
964-C2's Avatar
Default Torsion bar delete. Is it safe?
The upper an lower mounting for the shocks doesn't look very strong to me. Will they handle the extra load if you remove the torsion bars and put on coil overs?
How much weight will you save on this mod (how much does the torsion bars weigh) ?
Old 09-01-2009, 06:58 AM
MPD47
The Carnage King
MPD47's Avatar
This has been covered many, many, many times.
Old 09-01-2009, 08:30 AM
Chris White
Rennlist Small
Business Sponsor
Chris White's Avatar
Yea Mike!!!
Old 09-01-2009, 09:51 AM
Van
Van's Avatar
Yes
None
Old 09-01-2009, 11:34 AM
Chris White
Rennlist Small
Business Sponsor
Originally Posted by Van
Yes
None
Technically you are actually increasing the unsprung weight by half the weight of the coil springs...but the overall weight might be just ounces less.
Old 09-01-2009, 11:48 AM
shiners780
shiners780's Avatar
OK, next week Friday, after X number of beers, you and I are going to discuss whether the weight of a torsion bar is considered sprung or unsprung.
Old 09-01-2009, 12:04 PM
Chris White
Rennlist Small
Business Sponsor
Sprung....and I like my beer cold...
Old 09-01-2009, 01:42 PM
964-C2
964-C2's Avatar
Ok, thanks.
How much does a 25,5 (?) mm. torsion bar for a 951S weigh ?
Old 09-01-2009, 01:45 PM
Van
Van's Avatar
Don't know - but about the same as the coil over that you'll use to replace it.
Old 09-01-2009, 01:47 PM
Van
Van's Avatar
I agree with Chris - because of the hinge of the control arm, and the torsion bar is at the pivot point, the torsion bar would be completely sprung weight.
Old 09-02-2009, 09:58 AM
Chris White
Rennlist Small
Business Sponsor
"I agree with Chris" and i think that Van agrees that he likes his beer cold too!
Old 09-02-2009, 11:59 AM
vt951
vt951's Avatar
I would say torsion bars are sprung weight, because their mass is moved very little relative to the chassis (compared to the spring and coilover housing mass that moves with the wheels). Can I have a beer now, too?
Old 09-02-2009, 12:04 PM
Chris White
Rennlist Small
Business Sponsor
Sure - meet us at Watkins Glen for the first annual Sprung Weight Classic beer fest on Friday Sept 11th, all beer consumed is added to your sprung weight....until you 'spring' a leak...
Old 09-02-2009, 02:27 PM
vt951
vt951's Avatar
Ooh, we should take our Lemons car out there for a shake down! Kind of a long drive from Cincy, though.
I've asked a lot of people at the track about the torsion bar removal. Everyone says it has worked fine for them. The only failures I've heard of are the bolt at the bottom shearing or fatigue failure due to it not being installed properly (torqued down flush to the trailing arm).
Old 09-02-2009, 02:49 PM
Chris White
Rennlist Small
Business Sponsor
In the 'old days' some folks used to use washers so space the mounting point out for srping clearance - the Racers Edge mount fixed that problem (and made it work with standard sized rod ends)
Quick Reply: Torsion bar delete. Is it safe?
