FS 1 large oil cooler
Rainman
As title states, 1 large oil cooler for sale, I believe this is Setrab also but I cannot guarantee this. Unit is in excellent shape and almost all the fins are still perfectly straight as from the factory.These have 21mm compression fittings on the cooler (lines are included). This cooler has 11 rows opposed to the stock 951 cooler's 6 which should provide better cooling. Dimensions of the unit itself are approximately 13L x 5T x 2W".
This cooler will fit behind the foglights on an NA or 951, or nicely in front of the radiator.
Looking for $70 shipped. Included will be the appropriate pair of lines (one longer, one shorter).
Pictured with the unit is a stock 951 oil cooler for scale.
IMPORTANT: If you want this cooler and it sells before you get a chance, I DO HAVE MORE. I have a LOT of oil coolers stashed away in my attic that I picked up to use as heat exchangers for my supercharger project. I list them for sale as I pull them down and clean them as I need to pay my upcoming tuition. Send me a PM if you are interested.
Rainman
bump both sold
