How much step on a stock flywheel?
08-19-2009 | 10:29 AM
The flywheel I just took out of my car has been ground flat. Want to see if the machine shop can grind a step back into it.
Anyone know how deep the stock step is? Or have a stock flywheel they can measure for me?
08-19-2009 | 01:51 PM
Anyone even have a picture of the step?
08-19-2009 | 02:01 PM
there is no step. there is only the outer edge.
The mounting flange for the PP and the disk area are level to each other.
08-19-2009 | 02:11 PM
Okay, good.
I have read on here that it is a "stepped" fly wheel. Just want to make sure that mine will work fine with a flat surface. Thanks.
08-19-2009 | 02:14 PM
The NA flywheel is stepped.. maybe that is the confusion
08-19-2009 | 02:19 PM
Probably
I have read so many clutch posts I think my head is spinning.
