Six Speed Speedo Wiring?
Hi guys,
Jet951 is looking for the scematic on how he wired up a 968 six speed using the 968abs and the blue abs relay. I have all the parts and we are ready to get this setup correctly. We would just like to get it done NOW.
I appreciate JET951's help, and was wondering if anyone has done this and has wiring instructions. If JET951 finds his, that would also be great.
Appreciate all help.
George
George
I started with ABS setup in my car and the speedo was unusable. The LR kit is great but it requires some fabrication for a bracket. Since my mechanic did the 6-speed conversion and the retrofit of the LR components, I don't have any technical input.
It is an interesting upgrade. Steet driving is definately improved but I am less please at WOT. In my view, the gears are too close for cars above 350 RWHP.
I assume it'll be quite similar once the car's done (again). Only much, much better.
Here is how to hook up the 944 turbo with a 968 6 speed box.
you must buy 2 items,
968 ABS blue relay, part number 964 618 220 00
968 ABS control Unit, Part number 928 618 118 00
the 944 turbo ABS control unit, Part Number 928 618 119 05 does not have a speedo output. so it cannot be used
Here is a diagram i made up
Sean, the drawing shows a pin #9 on the Blue Frequency converter module. However, there is no #9 pin, but a #6 pin on the module. Could you confirm?
Based on a old document I have, it shows that #7 is GND and #2 is Power. Does this match your findings.
I lost the frequency module about 5 years ago, just found it with the instructions. Just in time to install.
George
